Replacement crank shaft different than original one????
1 reply to this topic
  • chrispy1202
Posted February 22, 2008 - 04:44 AM
I ordered a new crank shaft from the TT store (part #5TJ-11400-00-00), and put the engine back together to the point where the starter gear/clutch/rotor go back on. This end of the crank seems to be different, because the shaft is way smaller than the original rotor mount hole.:smirk: The rotor is supposed to be a squeeze on deal. Do i need a different rotor now??? Any help will be appreciated. I wll call the TT store this afternoon. Anyone else have this issue? I was looking forward to getting out for a ride this weekend.... this sucks!:)
Posted February 22, 2008 - 06:55 AM
Hmm... Sounds like you have an '03 crank and a later motor? Crank size was increased in '04.
