CRF150R powerband?
8 replies to this topic
  • tyman2395
Posted February 21, 2008 - 09:52 PM
those the crf150r have a powerband? My friends tell me it doesn`t because it`s a 4-stroke and the power is there all the time? if it has a power band how bad is it badder than the cr85?:smirk:
  • desertrider15
Posted February 21, 2008 - 09:57 PM
It all depends on the color. There is a sticker on top of the air box and it tells you how bad the powerband is.
Red: Bad
Blue bader
Pink: baddest
:ride: :ride: :)
  • tyman2395
Posted February 21, 2008 - 10:06 PM
No really does it have a powerband?
  • Farmerboy132
Posted February 22, 2008 - 07:05 AM
never ridden one, but it sure aint gonna be worst than a 85.
  • mcdavid32
Posted February 22, 2008 - 07:31 AM
tyman all engines have a powerband,a better word would be power curve,the crf150 is a 4stroke so the power curve is wider than a 2 stroke,kindda hard to explain im sure someone on here can do a better job than me.but niether a 2stroke or a 4stroke have a part in the engine called a powerband.
  • tyman2395
Posted February 22, 2008 - 08:42 AM
k thank you I will just have to test drive on to see.
  • silver_fox
Posted February 22, 2008 - 09:04 AM
The crf150r power comes on strong instantly right off idle. So to answer your question, it's not nearly as badderest as the CR85
  • shspvr
Posted February 22, 2008 - 09:38 AM
2-stroke have NARROW power curve usedly it hardhitting then drop at high rpm where a 4-stroke have WIDE power curve more smoother so a 4-stroke has a more manageable broader power band.
  • crf150f guy
Posted February 22, 2008 - 08:17 PM
all engines have a powerband. a powerband is the speed of the engine when it makes 75% or more of its maximum power or torque. trust me i know we have went over this many times on here. the 150r would have a wide powerband so it will have power almost all the time. unlike two strokes you dont have to feather the clutch to keep the rpms up.
