XL 350 Carb probs...
6 replies to this topic
  • Thumpmeister
Posted February 21, 2008 - 09:21 PM
I don't know how many of you guys go on the 250/400 forum, but I'm sure someone can help me with my problem...
Alright, I bought this bike in boxes after it had sat for years. I got it all together, and got it running. However, old gas had sat in the carbs for a number of years as well.
So, I cleaned the crap out of the carbs, cleaned all the parts, soaked what I could in carb cleaner for about a day too. I also got new fuel intake valves for both of the carbs, because the old ones were so shot that they would just leak gas all over the place.
Well, I did all this work, and the bike is almost impossible to start when its cold. There are many times when I'm kicking where it was almost start, but just doesn't quite get there. So, eventually I will have to bump start it, and finally it gets going.
Anyone have any ideas so I can get this thing to start easier?
  • martinfan30
Posted February 21, 2008 - 09:34 PM
Not quite sure, but have you tried the vintage forum? Theres lots of talk of these bikes there.
  • cleonard
Posted February 21, 2008 - 09:52 PM
It can be really hard to get everything out of the little passageways in the carbs. I like to blast the spray can carb cleaner through each and every passageway to be 100% sure that they are clean.
Those dual carb bikes are known to be hard to start. My friend has a XL600. It will start when totally cold or when hot. If it is just a little warm it is almost impossible to start. Too rich with the choke on and too lean without.
  • cleonard
Posted February 21, 2008 - 09:53 PM
It can be really hard to get everything out of the little passageways in the carbs. I like to blast the spray can carb cleaner through each and every passageway to be 100% sure that they are clean. Teh last time I brought an old dead bike back it took four rounds of carb cleaning before it ran right.
  • Thumpmeister
Posted February 22, 2008 - 10:06 AM
Yeah, I had an XL600 last year, and it was the same way. Would easily start when it was cold or warm, but halfway in between, no dice.
I've cleaned the carbs out three seperate times now, and have soaked the parts in carb cleaner. I replaced the fuel intake valves because it would always drip gas out the overflows. But its still a PITA to start cold.
  • Motosprtman
Posted February 22, 2008 - 10:37 AM
check the plug to see if it is wet, indicating of course that you are indeed getting fuel, if it is dry, check the float level and the float needle to make sure and adequate supply of fuel is getting to the carb. make sure the pilot cicuit is clean - blow compressed air through all circuits.
What year XL is this? 80's? or 70's vintage.
  • Thumpmeister
Posted February 22, 2008 - 11:11 AM
I did that, and replaced the plug. It looked like it was getting plenty of fuel. Might have been too much. I'm debating weather or not to adjust the air/fuel screw.
Its an 84, dual carbs.
