What is the best D.O.T Dual Sport kit and Cost
3 replies to this topic
  • Ernie_Taylor
Posted October 26, 2002 - 01:09 PM
I am looking for everyones feed back on the Dual Sport kits that they installed or are using and cost. I ride a WR426, 02.
Ernie
  • Rich_in_Orlando
Posted October 26, 2002 - 01:57 PM
Build your own, save a buttload of money. Depending on what you need, you could do it for less than $100. I got mine from Baja Designs, spent over $400, and it didn't hold up well. A friend built his from scratch for a few bucks and his works as well as mine does. And I've had to repair/replace almost every component in the 2 years I've had it. There are probably companies that make beter stuff but damn, have you seen the prices of some of those kits? Some are over $600.
  • Ernie_Taylor
Posted October 27, 2002 - 03:22 PM
I know all about the cost it's even more in good old CDN $$$
I just need to know what other people have done or bought.
Ernie
  • PumpkinHumper
Posted October 27, 2002 - 03:46 PM
First you need to know exactly what is required to be street legal in your area.
In michigan we need
1) hi/lo beem headlight
2) tailight/brakelight
3) Dot tires
4) mirror
5) horn
On my YZ400 I used:
1) electrex wr stator/flywheel kit $300
2) electrex voltage regulator $20ish
3) electrex brake pressure switch $20ish
4) Acerbis Blitz headlight $75
5) Ufo ktm underfender tailight housing $25
6) Acerbis mirror $15
7) Radioshack personal alarm $15 honda kill switch $5 makes the horn
I got away without the DOT tires. The cop diddn't catch it. I also dont have a hi/lo beam headlight. Although you could wire the 2 bulbs in the Acerbis with a toggle switch to resemble a hi/lo. A cop will never know the diff. Both bulbs are 35w stock on the acerbis.
I dont have blinkers and I dont have a battery. Some areas require these.
Hope some of this helps.
