Trouble in the Crankcase Please Help
8 replies to this topic
  • cheneyd3
Posted February 18, 2008 - 05:45 PM
I have a 2002 yz 426f and when I was repairing my drain plug hole on the bottom of the crankcase I accidently knocked the heli-coil tang into the bottom of the crankcase. Wondering if anyone had any suggestions on how to get it out without having to tear the entire engine apart.
  • 426boy
Posted February 18, 2008 - 05:50 PM
you could try to flush it out with some oil maby?
  • tntmo
Posted February 18, 2008 - 05:51 PM
I would try to flush the crankcase out, maybe you could use some diesel fuel or some cheap oil. Drain it into a container and see if the piece comes out.
  • cheneyd3
Posted February 18, 2008 - 05:57 PM
How can I flush the engine with oil. The yz 426f gets engine oil in the frame then is pumped through the crankcase and sucked back through
  • 642MX
Posted February 18, 2008 - 06:22 PM
Have you tried to use a small magnet?
  • cheneyd3
Posted February 18, 2008 - 06:26 PM
haven't been able to find one small enough to fit in the crankcase drain hole
  • 642MX
Posted February 18, 2008 - 06:37 PM
Take a pick with a 45 degree angle or one with a hook on it (or even a small screw driver). Rub a magnet back and forth on the metal shaft and on the tip, and then fish out your piece.
  • tnl
Posted February 18, 2008 - 06:42 PM
Is it possible on your bike to pull the left side case cover off to get to the bottom of the sump? Shifter side? Remove cover, flywheel, stator if needed etc.
Posted February 18, 2008 - 07:41 PM
Yes. You will have your best access to the sump and transmission area though there.
  • 5 replies
  • Hot  30 replies
  • Hot  36 replies
  • Hot  50 replies
