smokey starts
26 replies to this topic
  • martinfan30
Posted February 21, 2008 - 08:04 AM
#21
I have a 95 650L and when I got it ,it also smoked for a few seconds when started. After a few rides it doesn't do it anymore.
The previous owner told me he didn't use it for months when I bought it.
I have no idea also what that was.
That was probably a case of dry guide seals from sitting. Once it was being ridden again, the seals got some lube and started sealing again.
  • RODRIGUEZ
Posted February 21, 2008 - 09:04 AM
#22
Thanx
  • Dave Blackburn
Posted February 24, 2008 - 08:56 PM
#23
SOLVED!!
I think.
Here's what I did.
1st - Drop it on its right side, twice, busting your knuckles.
Then drain oil and remove clutch cover.
Clean and inspect oil pump/lines/screens.
Nothing is too bad, just normal build up.
Replace oil and go for a 60mile ride.
3 cold starts and no snoke, at all.
I hope it is fixed.
  • martinfan30
Posted February 25, 2008 - 07:55 AM
#24
SOLVED!!
I think.
Here's what I did.
I hope it is fixed.
So I dont understand what you fixed..... Oh well, at least its good now!:smirk:
  • xr650l bum
Posted February 25, 2008 - 09:04 AM
#25
Can you show us some video of the dropping technique. I am sure it will need to be done exact to make it work.
  • Dave Blackburn
Posted February 25, 2008 - 12:29 PM
#26
All you have to do is try to lean the bike on the handle bar away from the kick stand. Don't pay attention for a second, then miss the post you are trying to set the bar against catching your hand between the bike and your bench vise.
Repeat.
As for what I have fixed, I noticed that the oil level in the tank doesn't drop as fast as it used to. It would be almost empty after a few hours. I think it would totaly fill the case and push by the rings and smoke untill the oil pump caught up.
I must have cleaned out a check valve or something that was allowing the oil to drain quickly. :smirk:
Any ideas??
Thanks,
Dave
  • resurrection
Posted February 26, 2008 - 03:44 PM
#27
Check valve ? does that sound familiar ?
maybe when apart some junk got stuck? Some have springs that go bad and don't hold tight against hole .
I've found many a foul on many differant bikes with sump.
Good luck.
