flywheel weight recomendations
22 replies to this topic
  • TODD OVER
Posted February 17, 2008 - 06:40 PM
can anyone give me advice or opinion on what size flywheel weight to install on an 06 450 to help reduce or eliminate low rpm compression stall in slow tight technical sections of the trail? If so, who makes and sells em? Thanks
  • tnl
Posted February 17, 2008 - 07:17 PM
Call these guy's/gals: http://www.dubachrac...&products_id=28 I have the 6oz and am planning on returning it for the heavier one. There are alot of posts regarding this mod if you do a search.
  • Speedracer747-400
Posted February 17, 2008 - 07:23 PM
You could try adding a flywheel weight, but a Rekluse Pro will definitely fix your stalling problems. The the only drawback is the higher cost, but the advantages it provides are well worth it. If you decide on the flywheel weight the 9oz will most likely be a better choice for slow technical singletrack.
Rekluse z-Start Pro
http://www.rekluse.c...Start-Pro.shtml
GYTR Flywheel(Adds 4.83 oz)
http://www.yamaha-mo...7/0/detail.aspx
GYTR Off-Road Flywheel(Adds 9.21 oz)
http://www.yamaha-mo...5/0/detail.aspx
Steahly Off Road Flywheel(Adds 5oz or 9oz)
http://www.steahlyof...p?s_partnum=834
Posted February 17, 2008 - 08:27 PM
I don't think DRD makes weighted flywheels for the 06 and later models. They don't list them on the web site. I run the GYT-R Off-road flywheel (GYT-2S297-50-50), and it helps quite a bit.
Still, it's an MX bike with a tall low gear, and even with the extra weight, it doesn't have a huge amount of rotating mass. Clutch control and proper idle circuit jetting are important.
  • tnl
Posted February 18, 2008 - 06:23 AM
Great point! The extra weight helps but it's still not perfect considering what you said above. I found an uphill section that gave me trouble here in AZ in the past and after completing the hill I turned around and made numerous passes at it to practice on clutch control. It works!
  • TODD OVER
Posted February 18, 2008 - 11:34 AM
Thanks for the advice everyone, the recluse will have to wait for a brighter payday. I'll order the gyt-r flywheel this week, thanks for the part # gray!!
  • YZERIK
Posted February 19, 2008 - 11:56 PM
get the steahly 10oz, great unit
  • x2468
Posted February 20, 2008 - 12:38 AM
would a rekluse and a FWW together be overkill? or is it common?
  • DPW
Posted February 20, 2008 - 05:53 AM
I had the off-road GYTR flywheel weight on my '06 and it was the best mod I ever made to the bike. It simply enhanced the stock power and you loose nothing. I took it off my '06 when I sold the bike and just got around to putting it on my stock '08 the other day, but I have not had a chance to ride it yet to see if the results are similar or not.
  • Dano426
Posted February 20, 2008 - 07:13 AM
I ran them together on my YZ426. Its expensive, but not over kill.
Here is a chart to help you make your decision. http://www.steahlyof...arts.htm#YAMAHA
Give Steahlyoffroad a call. Before purchasing my 12oz they talked my ear off with info. Might be worth your time
  • Crabtree426
Posted February 20, 2008 - 07:35 AM
Dano is right on with the above statement. The guys at Steahly are really helpful. The owner will probably be who you talk to. Great company.:applause:
  • WB450
Posted February 20, 2008 - 09:25 AM
I ride trails only and I went with the.
http://www.yamaha-mo..../0/detail.aspx
It seems to work good.
  • WGP
Posted February 20, 2008 - 11:25 AM
I put on the Off Road GYTR too... I like it for off-road and it seems to start easier with the additional weight.
Funny Story: I ordered it from the yamaha dealer and just out of curiousity I asked the shop how much to install? They said 2 hours labor:eek: :applause:
I went home and had it on in 15 minutes:thumbsup:
(I did have to buy the Motion Pro Tool )
  • eazrider
Posted February 20, 2008 - 11:48 AM
I had a steahly 10 oz wt on my '04 450. I later added a Rekluse, and it was a bit much, lost a bit of snap. I now run the Rekluse alone, and it works great....
  • WB450
Posted February 20, 2008 - 12:32 PM
Did you get hosed on the puller?
  • WGP
Posted February 20, 2008 - 02:33 PM
Actually No...... MSRP 30$?
Good thing I had the part # and price for the Flywheel too.
Me " here's the GYTR part #"
Dealer " Do they show a price with that too..."
Me " Yes, $105"
Dealer " Oh , my computer has a different price in it, but I will charge you that"
A-holes:thumbsdn:
Posted February 20, 2008 - 02:49 PM
I didn't pay that much for the flywheel, but I bought it through TT OEM.
  • WB450
Posted February 20, 2008 - 03:11 PM
Me " Yes, $105"
A-holes:thumbsdn:
My dealer tried to hose me for like $50, he even thought the price was wrong and sold it to me for $10.95. I guess if the threads are on the inside it makes the puller worth a extra $40:banghead:
Posted February 20, 2008 - 04:32 PM
The internal thread, the fact that they are in two parts, and the low demand compared to the puller for the older YZF's do raise the price, but it should be $26.99, MSRP.
  • Wiz636
Posted December 08, 2008 - 10:54 AM
Does anybody happen to know the inertia mass of the Steehly +9oz flywheel? I'm trying to decide between that or the GYTR.
  • 0 replies
  • On January 15, 2017
  • Hot  28 replies
  • 10 replies
  • Hot  47 replies
