87XR600R Oil Trouble
5 replies to this topic
  • Jeremy2Wheel
Posted February 17, 2008 - 12:13 PM
Hey Guys,
I have a 87xr600r and it is loosing oil fast. I know these engines tend to leak some, but this bike just starting dumping oil. It looks like there may be oil coming out between the jug and the case. I know the jug is torqued to spec because I did it myself. Has anyone ever experienced this? Also, does anyone know if the engine to frame oil lines are interchangeable (between model years). They are no longer available for 87's and I want to replace the old ones on my bike. Any advice would be appreciated. Thanks.
  • Butta
Posted February 17, 2008 - 12:20 PM
Hey Guys,
So I assume you just did engine work on it. Did you remove all the cylinder base gasket from the two pieces? Were the sealing faces smooth and clean, flat as can be expected? Did you use any Hondabond on the surfaces when you put them together?
The new gaskets are pretty compressible, as designed for a good seal. You undoubtedly have to redo it. Check the sealing faces for flatness while you have it apart. I feel sorry for you, 'cause that gasket is a biatch to get off.
  • Jeremy2Wheel
Posted February 17, 2008 - 03:26 PM
The surfaces were clean and flat. I didn't use any silicone, just the new gasket. The funny thing is that it had been fine for about 6 months, then it just started leaking.
  • Jeremy2Wheel
Posted February 22, 2008 - 05:24 AM
So, have any of you guys with early xr600r's replaced your oil lines with those of a later model year? If not, does anybody know a place that can repair these old lines?
Thanks for your help. Any advice is appreciated.
  • creeky
Posted February 22, 2008 - 05:59 AM
Are the lines the source of the leakage you mentioned in your original post? If there is leakage around the base gasket, you might want to check and see if one of the cylinder retaining bolts has stripped out of the case. Over the years I have seen this happen a couple of times, in both cases there was oil leaking around the base gasket.
  • Jeremy2Wheel
Posted February 23, 2008 - 01:15 PM
Thanks for your reply. I don't think the oil lines are the main source of the leak. I am afraid one of the cylinder retaining bolts is loose, stripped, or broke. However, I still want to replace the oil lines. They are old and look like they could go at any minute. If I have to go to the trouble to pull the jug, I am going to replace the oil lines. So, I will gladly buy new lines from a later model year, but I am not sure if they will fit an '87 model. Again, thanks to all for any advice.
