Baja Kit Installed...NO Back brake!!!! Pls help!
12 replies to this topic
  • suz1100
Posted February 13, 2008 - 06:56 PM
I installed the Baja Kit from Baja Designs. All went well, except, I have NO back brake now!!!!
I bled the brake per the instructions, never letting the resrvoir run to low and now I have nothing. The brake does not feel "spongy" like there is air in the system. It feels like it did before I installed the new brake sensor, without the braking. :applause:
Any input will be appreciated.
Thanks!
  • Krannie McKranface
Posted February 13, 2008 - 07:41 PM
Thanks!
More info needed:
Can you pump the pedal to get brakes?
Is the pedal lower?
Is there any brake at all?
How long did you bleed?
If it is not spongy, then what is it?
I think you just have not bleed enough. It takes about 30 minutes of pumping/releasing.
  • suz1100
Posted February 13, 2008 - 07:51 PM
The pedal doesn't seem lower. I have VERY little to no brake. I bled the brakes for about 10-15 minutes max until I felt I had pumped the old brake fluid out.
Maybe you're right, maybe I should bleed it again for longer this time.
I thought that maybe I missed a step when installing the Brake Sensor which requires the removal of the "banjo bolt" (I think that is what it's called)
  • Thorndike
Posted February 13, 2008 - 07:57 PM
I think Kranni's right , you just haven't bleed all the air out. If you need to, try putting the back end higher than the master cylinder, air bubbles rise easier as you pump. But you should be able to bleed the air out either way
  • suz1100
Posted February 13, 2008 - 08:00 PM
Ok, thanks guys. I will give it another go. I guess I was a little to impatient :applause:
Thanks for the advice!
  • jdubb75
Posted February 13, 2008 - 08:35 PM
I just installed my B/D kit last weekend and had to bleed the brakes as well. I spent a good 30min at least and went through over half of a bottle of fluid before I couldn't see any more air bubbles. One thing I did that seemed to help a little was to not follow the Baja instructions on bleeding. I started out using them, but then I started doing it like I would if I were bleeding the brakes on a car.
open valve
push brake lever completely down
while still holding lever down close valve
release lever
Just keep and eye on the resevoir if you do it like this because it will drink the fluid a little faster.
By closing the valve when the lever is down it only allows fluid to flow in one direction when you release the lever...and that's from the resevoir to the master cylinder. If you leave the valve open when you release the lever and watch the fluid in the clear hose they supplied you will notice that it's trying to pull a little fluid out of it. And you know what's in the fluid between the master cylinder and the caliper...air bubbles. It just made more sense to me to keep everything flowing in one direction.
Posted February 13, 2008 - 09:26 PM
open valve
release lever
:applause:
This is the sure fire method; it's slow, painful, and effective.
  • Maroast
Posted February 14, 2008 - 03:42 AM
When I replaced the brake fluid in my xrr a few months ago i remember having to take a long time to bleed the rear brake. I've done dozens of car brake jobs and one hydraulic clutch....i think it took longer to get all the air out this bikes stupid rear brake than in all those other jobs!!! :applause:
  • Rockjockey
Posted February 14, 2008 - 05:01 AM
You might try the Mighty Vac brake bleeder, it works wonders.
  • suz1100
Posted February 14, 2008 - 06:48 AM
Guys, thanks again for the feedback. I will defnitely try "jdubb75's" suggested method.
I just got done SUMO'ing my XR and I guess I was too excited to get it on the road to try it out. :applause:
Patience IS a virtue I guess :)
  • Denn10
Posted February 14, 2008 - 06:53 AM
brake bleeders are the bomb for sure.
  • Thumpmeister
Posted February 14, 2008 - 09:05 AM
+1 for Jdubbs method. Slow, but definatly works.
  • martinfan30
Posted February 14, 2008 - 01:16 PM
As long as you have shop air!
  • Hot  35 replies
  • 17 replies
Honda XR650L 2016
  • 0 reviews
  • Hot  186 replies
  • 9 replies
