ACV Question
6 replies to this topic
  • okieguy
Posted October 24, 2002 - 04:25 AM
I just want to make sure I have this clear.
To disable the ACV all I have to do is reverse the diaphram so that the pin is pointing away from the carb?
What about plugging the air hole?
Thanks...
  • sabin
Posted October 24, 2002 - 05:42 AM
I personally removed it and I put another o-ring, because of you look on it you will notice that the diaphragm's end is like an 0-ring and it is made to fit only one way. I also plugged the air hole.
  • Dodger
Posted October 24, 2002 - 08:17 AM
Just flipped mine around, fit fine........
Peace
Dodger :) :D
  • Red3171
Posted October 24, 2002 - 10:23 AM
Just flipped mine around too plus took the spring out, so far so good......
  • BlueDragon
Posted October 24, 2002 - 11:26 AM
When you guys just flipped the diaphram around did you have to plug any holes? Did you have to change any of your jetting? :)
  • Red3171
Posted October 24, 2002 - 05:23 PM
BlueDragon,
I haven't had a chance to take mine into the hills yet. As of right now, I haven't made any changes to jetting nor have I plugged any holes. I'll let you know what happens.
RED
  • YAMAKAZE
Posted October 25, 2002 - 03:49 AM
If you leave any opening to the chamber exposed to air, sooner or later you will have a lean issue because of it. If the diaphram covers the hole and is serviceable you should not have an issue.
Bonzai :)
