02 yz426 seized, HELP
9 replies to this topic
  • chewy619
Posted February 11, 2008 - 02:42 PM
was just out rippin this afternoon and my 426 seized!!!! I thought before i started ripping into it, I'd ask everyone for there input on how theres seized and where, figured thered be a couple out there who had theres seize up and can tell me where to start, bike had oil in it btw.
  • roofer dude
Posted February 11, 2008 - 03:41 PM
I have the same problem with my 03 yz450f, I also have oil in mine. Anything I should do before I open it up? Any help would be great. Thanks
  • 642MX
Posted February 11, 2008 - 04:37 PM
Its not real common to hear about them seizing, but more and more older bikes seem to be locking the big end bearing up on the crank. Unfortunately 4 strokes typically don't seize the top end like a smoker does. Usually its the crank.
You need to start by pulling the motor out of the bike and start peeling parts off of it.
Posted February 11, 2008 - 09:03 PM
Yep, it's usually the rod.
  • LSmith
Posted February 12, 2008 - 05:20 AM
Just happened on our '04 450. Lower rod bearing seized.
Parts list was as follows:
Crank Assembly
Crank Bearings
Crank Seals
Cylinder (When the rod siezed, it forced the piston into the cylinder wall)
Piston & Rings
Cam Chain
Cam Chain Guide
Gaskets
Parts total (no labor) was just a shade over $700 from Service Honda with shipping - and yes, they sell OEM Yamaha parts.
  • YZERIK
Posted February 13, 2008 - 07:53 AM
how deos this rod seize? not riding for long time??????????????
  • 642MX
Posted February 13, 2008 - 07:57 AM
The bearing just gives out from use. Nothing lasts forever.
  • BASSic
Posted February 13, 2008 - 08:31 AM
Even a Yamaha?
I haven't heard about too many YZ failures, though I know they're out there. I wonder how hard the ones that are failing have been pushed and how well they were maintained?
Posted February 13, 2008 - 09:23 AM
Even a Yamaha? ... I wonder how hard the ones that are failing have been pushed and how well they were maintained?
The newest 426 is now fully 6 years old, and most of them have never been apart in any major way for any reason. I don't think I've heard of this on anything other than a high hour bike, and not at all since they upgraded the rod bearing last in '04.
  • 642MX
Posted February 13, 2008 - 09:43 AM
Even a Yamaha?
I haven't had one fail. But, I have replaced my crank just as good preventative maintenance. My bike gets rode almost every weekend and sometimes we travel 4-5 hours to ride, so failure isn't an option.
  • Hot  30 replies
  • Hot  36 replies
  • 5 replies
