oil cooler
6 replies to this topic
  • janner
Posted February 11, 2008 - 09:04 AM
Hi. Fitted a Clark tank to my 650L and I have noticed that without the original airflow scoops, indicated oil temp on my gauge has risen quite a bit.
Can anyone recommend an oil cooler modification?
  • martinfan30
Posted February 11, 2008 - 09:13 AM
Heres a pic of one Stepho is using.
http://www.thumperta...ad.php?t=599450
Alot of guys will adapt an XR400 cooler on the 650L. Pretty much mounts just like on the 400/250 XR's.
  • ToXicD
Posted February 11, 2008 - 09:30 AM
Go to eBay and buy a 450r oil cooler, their about twenty bucks and have mounting brackets. Already on them. All you have to do is cut the lines off at the metal tubing and thread the tubing with an 1/8ntp die and your ready for fittings and lines :applause:
  • Denn10
Posted February 12, 2008 - 09:53 AM
That cooler of the 450 a flat one like one on the 400ex?
  • ToXicD
Posted February 12, 2008 - 09:55 AM
yes it is.
  • Denn10
Posted February 12, 2008 - 10:00 AM
Ive thought about that myself just figuring a good place to mount is whats making me think about not using one of those. You got any ideas of where to mount that its not out in open like they do on a Slowsuki 650 inside that shroud on tank. Want to use it cus its a nice big cooler that would work awesome but just a bit big.
  • ToXicD
Posted February 12, 2008 - 11:08 AM
i have seen people mount them right above the front fender in front of the forks. if you worried about damage i guess you could put some louvers from a radiator over the cooler to deflect rocks and such.
