fork suspension settings
3 replies to this topic
  • jtn 06 wr450
Posted February 11, 2008 - 07:07 AM
not knowing much about suspension i am looking for what seems a simple problem answeered. (but im not too smart)
on the 06 wr450 if i bottom out the forks will the top screw turned to the + direction keep this from happening? of do i turn in the screw on the bottom of the fork?
the manual says the bottom screw is the compression but i thought it was the rebound dampening??????????????????????:applause:
i blew out a fork seal this weekend so i thought i better get this right.
  • KennyMc
Posted February 11, 2008 - 08:01 AM
I think you first need to determine if you have the proper springs for your weight. The attached link will give you the stock and then recommended.:applause:
  • jtn 06 wr450
Posted February 11, 2008 - 12:43 PM
thats an easy one. NO.
  • brad the best
Posted February 11, 2008 - 06:58 PM
then the first thing to do is to replace the springs with the recommended ones . you will notice a difference .
