Help Required - Rear Shock
1 reply to this topic
  • gio
Posted February 11, 2008 - 01:07 AM
Whilst working on my 99 YZ400 I noticed the relay arm bolt (bottom rear shock bolt) was sticking out about 10mm. I raised the rear wheel off the ground to replace the bolt and nut. I did not realise that no nut was required I assumed it was sheared off. The bolt is meant to go through the shock and screw into the other side of the relay arm, therefore no nut is required. Once I tightened the bolt and nut I lowered the rear wheel onto the ground. I sat on the bike and swingarm fouled against the nut. I realised I made a mistake by putting the nut on there and when i got off bike (HERE IS THE PROBLEM) the rear shock raised very slowly. (first time it's ever done this)
Q1. Have I damaged the shock or nitrogen cylinder by sitting on the bike.
Q2. Am I able to fill or re-pressurize the nitrogen cylinder.
Help required as I'm meant to go riding on Saturday.
  • William1
Posted February 11, 2008 - 04:21 AM
You may of bent the linkage arm. Remove and check for flatness. While these links are off, lift and lower the wheel, does it goes smoothly?
  • 5 replies
  • 0 replies
  • 9 replies
