07' 450F fuel. Clark vs. IMS?
22 replies to this topic
  • Johnny bad
Posted February 10, 2008 - 08:24 PM
I've read all of the reviews i could find and have'nt learned much. It seems both tanks are great and both stink, depending on who you ask. i'm not really concerned about comfort, I know I'll get used to the ergo's no matter. But I would like to here from anyone with direct knowlege relating to the install and fit of these tanks. Do the mounts line up? Do the shrouds fit? Does the petcock seat? And how about fuel line routing? Any heat related issues? That sort of thing. I just wanna get it right the first time. Thanks!
Posted February 10, 2008 - 09:19 PM
http://www.thumperta...918#post4069918
http://www.thumperta...398#post5491398
I have two of the Clarke "2.6" gallon tanks, which actually hold 2.8. Had I not found the second Clarke used at a good price, I may have chosen an IMS for my second one. My single biggest complaint with the Clarke is that the mount points are too far apart by about 1/4" to line up easily, which makes replacing the tank something of a PITA. Otherwise, it serves me well.
  • biwwy2000
Posted February 10, 2008 - 10:29 PM
i have had great experience with 2 clarke tanks....
1 on a xr650r
1 on a crf450x
both fit well and no modifications to make them work
the only complaint i have ever heard about the clarke tank is that if you are going to use a stearing stablizer then you have to check with the manufacturer for compatability/clearence with the tank.
from what i have heard ims do not have this clearance issue.
there is a thread on here about ims having an issue with rubbing the frame and creating a leak...........do a search because i would expect that ims has resolved that issue by now.
ps.....there is a warning out from the sergon general indicating that larger gas tanks lead to monkey butt.......... :applause:
  • cbrewer450
Posted February 10, 2008 - 10:31 PM
I have an 03 450F and I recently put the IMS on there and it lined up perfect. I really couldn't have asked for a better fit. I know it's not an 07, but I feel they make a pretty good tank.
  • diverb32
Posted February 10, 2008 - 11:14 PM
I have a 07 450 with an IMS 3.0
I switch it back and forth with the stock tank for mx all the time and it fits great. I can also get 3.2 gallons in it. I use a stock pet cock turned backwards so the outlet points to the carb and use the stock fuel line.
Posted February 10, 2008 - 11:40 PM
There is no issue with either tank on the aluminum framed YZ450 models relating to damper clearance, whether it be Scotts or GPR.
  • sirthumpalot
Posted February 11, 2008 - 05:47 AM
I replaced a cracked stock tank with a Clarke several years ago on my 01' 426 and the clark has been great. It was 1/2 the cost of the Yamaha OEM tank and is much thicker plastic (more durable). Pros: great price, fits good, very durable, perfect color match Cons: Gas cap takes more effort to screw on and remove (gets easier with time), didn't fit exactly perfect the first time I installed it (tight on the frame, shroud bolts not perfectly lined up), but after being on the bike it now fits just right. I think it just sat on the shelf and took a slightly new shape, but being on the bike put it back to its intended shape. Conclusion: I would definitely buy a Clarke again and I would recommend the brand to other people.
  • WB450
Posted February 11, 2008 - 08:29 AM
I like it e IMS 3.1, it bolted up perfectly, no leaking petcock, and it looks very nice.
  • Wiz636
Posted February 11, 2008 - 08:33 AM
I run the IMS on my '06. Fits great, no ergonomic issues, don't even notice a difference from the stock tank.
  • feirmeoir
Posted February 11, 2008 - 08:46 AM
:applause:
Where did you buy the black IMS tank?
  • diverb32
Posted February 11, 2008 - 08:49 AM
[quote name='WB450']I like it e IMS 3.1, it bolted up perfectly, no leaking petcock, and it looks very nice.[quote]
The black looks good!
  • IDAHOBALLER
Posted February 11, 2008 - 09:03 AM
:applause:
I was wondering the same thing?
IMO the black looks awesome with the white plastic.:)
  • WB450
Posted February 11, 2008 - 10:33 AM
[quote name='feirmeoir']:applause:
Where did you buy the black IMS tank?[/QUOTE]
[quote name='diverb32'][quote name='WB450']I like it e IMS 3.1, it bolted up perfectly, no leaking petcock, and it looks very nice.[quote]
The black looks good![/QUOTE]
[quote name='IDAHOBALLER']I was wondering the same thing?
IMO the black looks awesome with the white plastic.:)[/QUOTE]
Thanks, I have the paper work at home and I'll check it tonight and let you know. I think I got it for a great price too. I found this site that shows a 3.0 black.
http://www.procycle.us/tanks/ims.htm
http://www.cyclebuy....aha_4stroke.htm
  • crfoot
Posted February 11, 2008 - 11:04 AM
I just bought the Clarke 2.6 gallon for my white 07 yz450. I got it in black and looks like it came with it! I got it at cyclebuy. Live in California so no tax!! To get black he just called Clarke and special ordered it. 1 week at my door. No problems and happy with it.
  • FLYIN400F
Posted February 11, 2008 - 02:39 PM
great timing on this im getting ready to purchase a large capacity tank, however the link to the TT store only shows old ims tanks, I need one for an 07
Posted February 11, 2008 - 04:58 PM
.. the link to the TT store only shows old ims tanks, I need one for an 07
Call them.
  • rexbond007
Posted February 11, 2008 - 07:22 PM
i just got my clark 2.6, in black bolts lined up, cheaper than ims, just a little hard getting the seat on. but ok and happy with it.
  • WB450
Posted February 12, 2008 - 08:03 AM
I looked at my paper work, and it looks like I bought it through
MOTORSPORTS NETWORK
5198 ARLINGTON AVE. SUITE 103
RIVERSIDE, CA 92504.
Down at the bottom $249.95
http://www.motorspor...uct=Tank MC Yam
The invoice looks direct form IMS. The part# on the invoice is the same as the # on the IMS web site. No price is listed on the invoice, but I know I didn't pay the $274.95 that IMS is asking.
https://www.imsprodu...rt/viewcart.cfm
  • tnl
Posted February 12, 2008 - 11:29 AM
I have a 05 IMS 3.2 and would recommend it! IMO, I think the IMS looks better at the cap or top of the tank. The Clarke tanks just stop suddenly at that location and looks stubby. http://Posted Image
  • phatty
Posted February 12, 2008 - 01:54 PM
On the natural tank, is it see through? I would love a clear tank to just see how much fuel is left...
  • Hot  50 replies
  • Hot  113 replies
  • On January 15, 2017
  • Hot  28 replies
