help!
No replies to this topic
  • UK Bosch
Posted February 10, 2008 - 11:15 AM
I have a 2004 yz450 that has had what i presume is a wr lighting kit fitted to it (no battery). I took it out today and noticed that the brake light works fine (led) but the rear light is now non existent (led) and front dipped and main is only just glowing yellow a tiny bit if you look hard. put a meter on the headlight and it's between 2-3 volts? Any ideas where the problem might lie? The cables all look ok to me an the switchgear is a little dirty but doesn't look like it's shorting anywhere. Just want to pick your collective brains before i strip the whole loom out.
cheers
