Oil leak out of decompression toggle thingy on '98 yz400f
3 replies to this topic
  • Twoply
Posted February 10, 2008 - 08:55 AM
I have a drip of oil coming out of where the decompression lever thingy goes into the engine block. I cant find the part number for the bushing/ washer plug that needs replacement.
ANy help here?
THanks as always
  • Speedracer747-400
Posted February 10, 2008 - 09:30 AM
93102-12224-00 OIL SEAL
Be very gentle when tightening the screw in the side of the cylinder head that holds the decompression assy in place. The threads can be easily stripped.
  • wolfgang2010
Posted April 10, 2016 - 06:18 PM
If so happens this is stripped out (witch in my case it is) what can be done to fix this?
Posted April 11, 2016 - 06:19 AM
You will need to re-thread the hole using a Heli-Coil.  The original bolt or a replacement must be used, as it has a pin on the nose of the bolt that retains the shaft.
  • Hot  38 replies
  • Hot  30 replies
  • 10 replies
  • Hot  113 replies
