Jetting & Suspension results !!!
51 replies to this topic
  • Bill
Posted May 06, 2002 - 12:21 AM
#41
Pete,
That is the final configuration, unless Taffy tells me to try anything else.
Good Luck
Bill
  • Taffy
Posted May 06, 2002 - 08:45 AM
#42
that's great bill.
you may find that the neelde lowered one would make it a little crisper at roll-on in 4/5th gears.
ride it like that for a while. you'll be amazed, but one day in one gear at one speed you'll catch the bike out. just report it back and we can adjust to suit.
Taffy
  • WRFUN
Posted May 06, 2002 - 11:14 AM
#43
Bill,
If you dropped your needle twice I thought you would be lower that clip 6. Lower number = Leaner correct? I'm in jetting overload :)
Pete :D
  • MN_Kevin
Posted May 06, 2002 - 11:30 AM
#44
clip in # 1 position is at the top of the needle -needle is inserted as far as it can go = lean;
clip # 6 is at bottom of needle - needle is pulled as high as possible = rich.
  • Bill
Posted May 06, 2002 - 01:33 PM
#45
OK, so according to Kevin (I'm sure he's right) I have the clip in position #2. I was lowering the needle by raising the clip.
Sorry :)
Bill
  • WRFUN
Posted May 06, 2002 - 03:31 PM
#46
Bill,
Thats OK.....Thats why the class is called jetting 101, and I'm sitting in the chair right behind you :) . Lucky for us we have great professors !!!!!!!!
Pete
  • Taffy
Posted May 06, 2002 - 11:10 PM
#47
bill
if you've got that needle in clip 2 (second from the top) you're running spot on/lean.
if you have got thath 35PJ and can turn the PAJ down to 45 i would definately try it.
Taffy
  • Bill
Posted May 07, 2002 - 02:47 PM
#48
Taffy,
If the new PJ config does not work. Will the change result in a bog or what should I be listening/feeling for?
Otherwise it's the ole "seat of the pants" dyno :D :)
Bill
  • Taffy
Posted May 07, 2002 - 08:48 PM
#49
bill
what else can i say other than it will be better!
you may even get that huge rise in tickover (idle) that i had. this as you know means the bike is at last getting exactly what it wants.
you may find that the bike operates off a smaller throttle?
now you've said that the needle is lean on it's clip position i would check if lifting the needle one clip isn't better. all you need to do is roll-on back-to-back tests by riding flat out in fourth on tall gearing at say 15/48, roll the throttle off for a count of "one" and go again. do it on the road and not the dirt if you can.
then try the 35PJ/45PAJ combo.
keep the faith. these are tests and you've walked through a lot of work to get to here.
like i've said before, having offered up these jetting #s people are just sticking stuff straight in and offering little testing or feed back.
someone literally last week said "it works, so i'm off". :) he may have said Ta! but i don't remember.
hardly did his bit for the cause though did he.
if it helps do the testing as a straight chore and don't have any rad flaps, one bolt in the seat and tank etc.
Taffy
  • WRFUN
Posted May 13, 2002 - 11:41 AM
#50
Professors,
I received my Pilot jets on Friday and was ready to test on Saturday BUT.....
1st run: Delayed because of rain. :)
2nd run: Delayed because of rain. :D
3rd run: Flooding.... :D
OH......did I say anything about the rain :D
Maybe this weekend.
Pete :D
  • Taffy
Posted May 13, 2002 - 12:55 PM
#51
somebody pull my teeth for me :D :D
hand slaps forhead
Taffy (still :) )
  • S_Phillips
Posted May 13, 2002 - 03:21 PM
#52
just what are you trying to tell us Taffy :)
