Tips on puttin a white bros fuel screw in 06 yz450
5 replies to this topic
  • ktown yamaha
Posted February 09, 2008 - 07:50 PM
hey guys i just bought a white bros fuel screw for my yz any pointers on puttin it in, anything that would make install easier, thanx
  • Wiz636
Posted February 09, 2008 - 09:21 PM
Just be careful that you keep track of the spring and tiny little washer and o-ring!
  • ben_suhard
Posted February 10, 2008 - 06:46 AM
Installation(and removal later) is easy, the difficult part is getting the OEM screw out! If you don't have one of those fancy fuel screw adjusters or can't get a screwdriver in there, you'll have to tilt the carby, which requires removing the seat, tank, upper engine brackets and hot-start. Try to get a small screw driver up there! Removing the hot-start can be a good thing 'cause it's important to keep it greased up inside to prevent it from siezing.
  • mulisha00
Posted February 10, 2008 - 06:51 AM
get a flat head bit from a cordless screwdriver and turn it by hand with just the bit.:applause:
  • CO_Rider
Posted February 10, 2008 - 10:30 AM
^^^Thats what I did. If you find it to hard to turn by hand use a small end wrench that you can fit over the end of the bit and use that to help you turn it to get it out. It can be kind of a pain but its well worth it and you only have to do it once because you wont be going back to the stock one :applause:
  • ktown yamaha
Posted February 10, 2008 - 09:43 PM
right on guys thanx for the tips should make puttin it in a lot easier
  • Hot  36 replies
  • 10 replies
  • Hot  113 replies
