98 replacement kick start lever
3 replies to this topic
  • hsstar
Posted October 23, 2002 - 09:13 AM
Kick lever broke at the knuckel right down the cast seam at the ball lock hole.
My question I post to all you Gurus is , Which replacement should I get?
I have heard that Yam knew about this problem have the newr bikes been having failures? What year would fit? Is a 426 lever stronger at the knuckle? Or should I order the Billet model?
  • MOmilkman
Posted October 23, 2002 - 11:11 AM
If money is not an object then a trick BBR lever would definatly be the way to go, but if it is, then heres one on e-bay.
It even came off a 98 model.
Although finding one off a 99 or later would be better since they supposedly corrected that problem.
  • MotoGreg
Posted October 23, 2002 - 07:17 PM
I've been using this one for three years now with no problems. It looks neat and it's a little shorter than the stock kicker so it's more comfy, you don't have to wrench your hip as much to get your boot up on it.
Click here for info.
Posted October 24, 2002 - 07:11 AM
Dammit ! stop that...Now I'm going to be in more trouble.....
Bonzai :)
