Linkage maintanence
7 replies to this topic
  • djtroy
Posted February 09, 2008 - 10:46 AM
Hey
I am going to attempt to do maintenance on my 2006 yz450 linkage considering it has never been done. I am an average mechanic at best is there any special tools or lubes I might need to pick up before hand? Any special tips or trick on the 450's I might not know about? I plan on printing off a few older how to posts as some sort of a guide but I know you guys in here with the same bike might be able to help me out with some specifics.
Thanks
  • KAS
Posted February 09, 2008 - 11:19 AM
Use a quality waterproof grease.
Take your time!
Take lots of detailed pictures beforehand in case you forget how something goes back together.
Be careful the needles don't all fall out when you're packing the bearings. Perform the work somewhere you wont easily loose them if they do.
Keep track of what bolts/nuts/washers go where.
And again, take your time!!!! Its an easy job, just somewhat time consuming.
Posted February 09, 2008 - 01:02 PM
This is a good link for the purpose:
http://www.thumperfaq.com/swingarm.htm
Note that you will not find any of the "string cheese" in an '06+.
  • ncmountainman
Posted February 09, 2008 - 01:36 PM
if you end up having to change them do yourself a favor and get a motion pro or comparable bearing puller:thumbsup:
  • KJ790
Posted February 09, 2008 - 03:46 PM
If you've never done it on an 06, odds are you will have to replace some bearings. If you do, you will learn why it is important to keep them greased. It is much easier to grease them once in a while than to change them.
  • djtroy
Posted February 09, 2008 - 04:06 PM
Sounds like its gonna be nice and easy. No tips means no troubles Im hoping.
  • Ga426owner
Posted February 09, 2008 - 04:19 PM
Be patient and have something to help leverage the weight of the rear wheel - I suggest replacing the shock bearings as they are usually the first to go from normal wear. Pivot Works has a good kit for this and the other linkage bearings if they need replacing
  • djtroy
Posted February 09, 2008 - 05:46 PM
Thanks Ill check em out.
  • Hot  50 replies
  • Hot  113 replies
  • Hot  47 replies
  • Hot  38 replies
