Idle overrun after hard riding???
5 replies to this topic
  • Kylelind
Posted February 08, 2008 - 03:49 PM
So, went riding for the first time on my 2000 426 yesterday and had a little problem with the idle staying high after getting off the gas. Like after doing a hill climb I would let off the gas at the top and it would idle much higher and not decelerate very well. I just jetted it a little richer and have not messed with the fuel screw. Could that be the answer if it were out too far? The bike idles fine after a minute of higher idle and starts easy.
  • gbalias
Posted February 08, 2008 - 04:27 PM
how far out on the fuel screw?
i had this problem last week and found that my fuel screw had worked its way out a lil bit.
  • William1
Posted February 08, 2008 - 04:48 PM
A hanging idle is often a sign of a too lean pilot circuit. Assuming you did the fuel screw/pilot test and the adjustment is correct, try opening the fuel screw 1/2 turn.
My WR ran fine with the screw at 1 turn, but the idle hung from time to time. Did a A/F check and found it needed (wanted??) to be closer to 3 turns to be the right ratio. Hanging idle, decel popping disappeared!
Posted February 08, 2008 - 05:03 PM
It can also indicate insufficient intake valve clearance.
  • William1
Posted February 08, 2008 - 06:20 PM
Good point, Gray. I failed to notice the age of the bike. Questions, questions.... :busted:
  • Kylelind
Posted February 08, 2008 - 06:43 PM
Yeah, I have not done the test yet but will tomorrow. Thanks for all of the help and keep it coming if there are any more suggestions.
