2001 wr426
3 replies to this topic
  • davesltz400
Posted February 08, 2008 - 08:29 AM
I just wanted to know if the 2001 wr426 is capable of the gray wire mod.:busted:
  • jbrooks26
Posted February 08, 2008 - 08:59 AM
Yes, but it is not in a 6 wire connector like all of the Corrections say. It is in a two wire connector with a black wire. Disconnect only the grey wire and you should be fine. Hope this helps.
Josh
  • Wr426rdr
Posted February 08, 2008 - 09:03 AM
I did the grey wire mod on my 01 WR426, and it rocks! Definite mod!
  • Pooley
Posted February 15, 2008 - 12:52 PM
Yes it is. As well as the light blue wire mod (neutral detect circuit), BK mod, throttle stop, O-ring mod (better than BK btw), remove the exhaust restrictor for a 96dB insert (like GYT-R). And if you are going to do the mods, rejet using the JD Jetkit.
