Oil in flywheel
6 replies to this topic
  • hotdog7
Posted February 07, 2008 - 01:17 PM
On my wr 2002 wr426 I checked the valves today and when I took off the two caps to line up timeing mark I found oil inside caps and on flywheel is there supossed to be oil in there?
  • William1
Posted February 07, 2008 - 01:37 PM
Yes, all is ok.
  • JS264
Posted February 07, 2008 - 03:03 PM
You are thinking 2-stroke. There is supposed to be oil in there.
  • 02WR426Cali
Posted February 07, 2008 - 04:51 PM
Yeah I had the same problem. I had worked on a bunch of 2 strokes and then all of a sudden I tap into my 426 and it's full of oil. I got scared for a minute, but then I found out it's normal. There is no crank seal on 4 strokes like there is on 2 strokes.
  • hotdog7
Posted February 07, 2008 - 07:07 PM
Thanks I was sh**ing in my pants thought I was in real trouble. My xt has no oil on that side of the motor
  • MotoGoalie
Posted February 08, 2008 - 08:15 AM
Uh, isnt your OIL FILL hole in the Flywheel side of the crankcase?:busted:
XRs are the same way, BTW.
  • 02WR426Cali
Posted February 08, 2008 - 03:35 PM
Nope, not on the 98-02 models. The fill hole is in the downtube of the frame in front of the gas tank. This system holds more oil and is a better system in my opinion for off road riders such as myself.
