08 WR 450 help with YZ forks
19 replies to this topic
  • STECKNINE
Posted February 07, 2008 - 12:23 PM
I have 08 wr450 and, 08 yz forks. They slid in the clamps just fine but, the right fork guard wont line with the yz holes. Then there is the odo thingy:banghead: Please help Josh S
  • 123BigcoopDawg576
Posted February 07, 2008 - 01:24 PM
your going to need yz fork guards and yz wheel spacers
  • Jeff_Steckline
Posted February 07, 2008 - 03:43 PM
Why would you need YZ wheel spacers? Jeff S
  • Frostbite
Posted February 08, 2008 - 04:21 AM
The older WR's incorporate the drive for the odometer in one of the wheel spacers, and that side of the YZ wheel is a bit different. It probably the same on the new models. I noticed this when I bought a used front wheel for a spare, and it was from a YZ.
No big deal, but you need the YZ spacer for the left side.
  • Island Boy
Posted February 08, 2008 - 09:41 AM
I put 07 YZ SSS Forks on my 07 WR. No problem with fork guards or spacers???? Are you using your WR fork guards?
  • STECKNINE
Posted February 08, 2008 - 12:23 PM
It seams the left fork guard will fit but, the right one has a different hole pattern. The other problem I am having is the brake caliper mount is a different size...
  • Island Boy
Posted February 08, 2008 - 12:36 PM
I can absolutely confirm that 07 YZ SSS forks fit perfectly on the 07 WR (WR caliper and WR guards line up exactly ). I cant recall any major change to these parts in 08. There should definitely be no problem with the odometer fitment as long as you are using a WR Wheel and WR fork Guard on the YZ forks.
Where did you get the YZ forks from? Are you sure they are from an 08?
  • STECKNINE
Posted February 08, 2008 - 12:46 PM
I got them on E Bay from keepitroostin. I have e mailed them but no reply back so far.:busted:
  • rbn14
Posted February 08, 2008 - 01:37 PM
The caliper mount and fork lugs must have been updated in 2008.
2008
Part numbers
2007 Posted Image 2008 Posted Image
  • STECKNINE
Posted February 08, 2008 - 05:11 PM
Should I gulp or swallow?:busted:
  • Jeff_Steckline
Posted February 09, 2008 - 06:52 AM
I also have a 07 WR with 07 YZ forks, they slide on with no changes, wheel spacers etc are not needed. Stecknines problem is from a 08 WR to a 08 YZ fork set up. The caliper is different and so are the fork guards. To solve your problem all you need to do is spend more money. Buy 08 YZ fork guards, yes you will have to modify these. Back to e-bay for a 08 caliper off a YZ and you should be fine.
You should of asked your big brother first, (your not supposed to gulp your food, try swallowing). Jeff S
  • MATTH530
Posted February 09, 2008 - 06:03 PM
The 08 yz axle is different than the 07. Yz wheel spacers are the same 08 / 07.
I tried to use my reklus e-axle on the 08 and one side of the fork is a different size, axle will not go through.
Matt
  • rbn14
Posted February 09, 2008 - 07:11 PM
That is good to know Matt. You get that Stecky? Back to ebay...
  • STECKNINE
Posted February 12, 2008 - 07:18 AM
Thanks for all the input! once I get all the parts and, slap them together Ill let you guys know how they are..:applause:
  • mavis0826
Posted February 13, 2008 - 06:49 PM
I now fined myself with the same problem. is it possible to change the lower part of the fork, the part that has the caliper mount on it? also is the fork from a 07 250f have the same caliper mount problem?
  • rbn14
Posted February 13, 2008 - 09:19 PM
The 07 works works fine. The axle lugs are damn near impossible to remove and I dont know if you can even buy them.
  • Jeff_Steckline
Posted February 14, 2008 - 06:04 AM
If you bought a 08 fork set up off a YZ, you will need 08 YZ axle and spacers, caliper and fork guards. Yamaha must of realized that we were swapping parts and they were not making a profit from it. Jeff S
  • freerider_australia
Posted February 18, 2008 - 12:04 AM
are the yz forks really much better ?
  • Jeff_Steckline
Posted February 18, 2008 - 07:53 AM
Yes, though Factory Connection revalved a friends 07 front and back, I'm impressed how well they made the stock fork work. I've never riden a bike so well balenced. I raced 102 miles yesterday of which 101 miles were deep whoops :applause: , the stock YZ forks worked well, way better then my revalved WR forks. Today I will be sending Factory Connection my suspension, with the blisters I have on my hands I won't be needing to ride for a week or so. Jeff S
  • sausage boy
Posted July 18, 2008 - 04:23 PM
Yes, though Factory Connection revalved a friends 07 front and back, I'm impressed how well they made the stock fork work. I've never riden a bike so well balenced. I raced 102 miles yesterday of which 101 miles were deep whoops :thumbsup: , the stock YZ forks worked well, way better then my revalved WR forks. Today I will be sending Factory Connection my suspension, with the blisters I have on my hands I won't be needing to ride for a week or so. Jeff S
i'm in a similar position, YZ forks or not? the forks from my 08 WR450 are at factory connections right now, i scrached one of the lower fork tubes so i sent them to factory connections to have a new fork tube put on and to get them revalved and re-sprung for my weight. problem is the fork tube is on back order from Yamaha and is going to take 2 weeks to get to FC. the price for the fork tube and the re-valve is almost the same as a brand new set of YZ forks. is it that much trouble fitting the YZ forks?
