Jetting questions
8 replies to this topic
  • F2504X4PS
Posted February 07, 2008 - 06:04 AM
Hi all, I just picked up a 1998 XR650L with 10k miles on it, I'm getting ready to pull the carb out to check for mods (if any). I plan to do the Dave's mods to it. what I can see from the outside is I have a full Youshumri exhaust system (header and pipe), UNI air filter. My questions are: what jets to use, (I'm in Atlanta Ga.) and also what to look at to check for "uncorked" airbox, if it's still corked I will uncork it if someone would tell me how :busted:
I plan to ride the bike 90% street.
So with my after market exhaust, uncorked air box and uni filter, would I stay with Dave's reccomendations of 55/158, .030 needle shim, mixture screw out 2.5 turns, and slide drilled out to 5/32?
Ya'll are better than a factory maintenance manual :worthy:
Best wishes and Thanks in advance for your knowledge.
Steve.
  • martinfan30
Posted February 07, 2008 - 07:43 AM
[quote name='F2504X4PS']Hi all, I just picked up a 1998 XR650L with 10k miles on it, I'm getting ready to pull the carb out to check for mods (if any). I plan to do the Dave's mods to it. what I can see from the outside is I have a full Youshumri exhaust system (header and pipe), UNI air filter. My questions are: what jets to use, (I'm in Atlanta Ga.) and also what to look at to check for "uncorked" airbox, if it's still corked I will uncork it if someone would tell me how :worthy:
Ya'll are better than a factory maintenance manual :ride:
158/55 is a good start. Whats your ele.? If the airbox is NOT uncorked, there will be a "snorkel" riveted to the air intake on top. All you need is what "dave's mods" recomends.:busted:
  • F2504X4PS
Posted February 07, 2008 - 07:56 AM
I believe it's about 1000 ft.
Oh and another note: it still has the smog pump installed, I ordered the block off plates this morning to remove that contraption.
Thanks, Steve.
  • martinfan30
Posted February 07, 2008 - 09:52 AM
Just do what you already have planned, including smog removal. That jetting will be fine at that ele.
  • mrfreeze54
Posted February 10, 2008 - 06:49 PM
Where is a good place to buy the jets needed to do Dave's Mod???
Thanks in advance.......
  • martinfan30
Posted February 11, 2008 - 09:00 AM
Local dealers usually have them.
  • Denn10
Posted February 12, 2008 - 09:58 AM
there about $4/5 each, sounds like you got what you need just have to Get-r-done. jetting should be darn good for ya.
  • F2504X4PS
Posted February 13, 2008 - 03:58 AM
Thank's for the great advice, I hope to have Dave's mods finished soon.
Steve.
  • Denn10
Posted February 13, 2008 - 08:27 AM
http://www.4strokes....xr650lcarbmods/
link if ya need it with pics.
  • 22 replies
  • Hot  35 replies
  • 4 replies
  • 17 replies
Honda XR650L 2017
  • 0 reviews
