Digital Speedo on 2007 WR
38 replies to this topic
  • tweav
Posted February 08, 2008 - 04:37 AM
#21
Well I checked the drawings they are the mostly the same . not anything differant at the computer wiring. so I pulled mine off. and looked at it close I found a jumper wire in the back , So I clipped it , it did not change anything so I hooked it back up , I guess they are just programed slightly differant . I'm getting a vapor . this thing is dumb . for those for of you who love the thing you can make a handle bar remote control using the wires in the 4 wire plug.
1 brown + black = slct1
2 dark green + black = slct2
3 yellow + black = rst
  • KennyMc
Posted February 08, 2008 - 07:53 AM
#22
Hi, here in south africa our versions of the wr450 got the total km (not resetable) and the "a" & "b" trip, funny you guys dont have it????
Is there a paticular sequence of buttons you need to push to get to the total milage? My current display is for A but it is easily switched to B. How do you get to the Total?
  • simonreeves
Posted February 08, 2008 - 10:09 AM
#23
i'm glad it's not just me that can't work the damn thing. I played with it for hours & got what i thought was total miles, now i'm not so sure. Maybe i'll just leave it well alone.:busted:
  • tweav
Posted February 08, 2008 - 12:00 PM
#24
the usa models got screwed even more . all those guy do to get to the total is keep hitting the the slct2 button it should scoll thru in this order: odo - trip a - trip b - trip a - odo
the fantastic usa model goes, trip a ,trip b, trip a, trip b
completely stupid
  • William1
Posted February 08, 2008 - 04:40 PM
#25
For those that have an actual, accumulated mileage odo in your country, would you look up the part and supply the part number of the speedo instrument?
  • tweav
Posted February 08, 2008 - 05:37 PM
#26
it's much cheaper just to buy a vapor I got one for my bike with the aluminium protector for 143 shipped today
  • William1
Posted February 08, 2008 - 06:18 PM
#27
I know, I wanted the part number to dissect it and try to find out the actual differences. Yamaha part numbers tell more than simply where the part is located on a shelf and on the bike. Certain values in it define function and interchangeability. With the number, I just might be able to get the odo function working on my stock unit.
  • tweav
Posted February 08, 2008 - 06:38 PM
#28
I tryed All kinds of stuff with mine with no luck . Oh and mine loses all memory when it is unpluged . somebody earlier in this post said it will keep data without the battery. I even tryed cutting the jumper wire , I even hooked a backup battery to the jumpers wires. and still nothing . so we can use mine for a crash test dumbie . So just tell me what you want to try . instead of testing on your's . I'll set mine up on my work bench
  • Haro
Posted February 08, 2008 - 10:40 PM
#29
Wow, that Yamaha site needs some updating.... 2001 is the most recent WR, and if you go by year, it only goes to 2003.......
I can even pull up 2008 model year...:busted:
  • tweav
Posted February 08, 2008 - 11:17 PM
#30
I can even pull up 2008 model year...:ride:
Yeah I pulled up a 2007 . I just didn't say anything. maybe he's got dial up ..:busted: :worthy:
  • KennyMc
Posted February 09, 2008 - 12:06 AM
#31
I knew dial-up was slow, but 7 years...:ride:
  • KennyMc
Posted February 09, 2008 - 01:02 AM
#32
Well, since this project has hit a stand still, I figured I would go out and install my BRP Scotts damper I just got from the TT store. Man olmighty, what a delivery success fro TT. :busted: :worthy: :ride:
I ordered it from TT, which in turn ordered it from BRP since I wanted their top mount. BRP sent it out on Thursday to TT. TT sent it out to me on Friday. I now have completed the install:thumbsup: We it took me 2 days (11:00PM Friday to 12:30AM on Saturday)
  • William1
Posted February 09, 2008 - 03:14 AM
#33
I was trying open the AU site, not the US one. Just went back in, it is not the same as when I went there the first time. Must of been yupdating it when I was trying to see last time.
No dial up here, fiber to the router in my house.
  • William1
Posted February 09, 2008 - 03:19 AM
#34
I knew the comment about it having a backup battery was incorrect. Both the value for the clock and trip meter are held in volitale RAM. If there was/is a odo, the memory for that is most likely in 'bubble RAM'. This memory type does not need a power source to retain info. The South Africa part number may provide some insight. Failing that, I can speak to Yamaha directly (I am an ex-factory tech for Yamaha USA and have some contacts).
  • motomanny
Posted October 29, 2008 - 08:43 PM
#35
hey I have an even dummer question... how do you set the damm thing in the first place...I have a 2008 wr450 but no owners manual and my odometer/ speedometer only reads 0 even when moving I have no idea how to set the thing to tell me how fast im going and how many miles my current trip is.....help!!
  • tweav
Posted October 29, 2008 - 10:31 PM
#36
here's a link to a online book pdf file of a 07 wr450
It's a fairly big file so it may take some time to download . like 22megs
http://ymenvom.nl/manuals/M5TJ44.PDF
  • RSAthump
Posted October 31, 2008 - 07:29 AM
#37
Ill check mine for you guys, mine also keeps total milage, from South africa too, Ill send you part number. Aussies? Brits? Are yours the same as ours?
  • Bradical
Posted October 31, 2008 - 02:39 PM
#38
In Canada we also get the odometer function. Strange that they would bother having two different units in North America.:lol:
  • tweav
Posted October 31, 2008 - 06:01 PM
#39
I can explain why the U.S.A. bike have a worthless speedo ....It very simple We nuked japan and they are still pissed off.
