steel to aluminum change over
2 replies to this topic
  • thumpyz
Posted February 06, 2008 - 04:59 PM
I was curious how hard it would be to transfer as many parts as possible from a 04 yz450 frame to an 06 yz450 frame. I realize that it might take an 06 swing arm, but I am not sure about anything else. Does anybody have any ideas?
  • KJ790
Posted February 06, 2008 - 05:13 PM
The engine on the YZ450 was redesigned for 06, so your engine is different. That said, anything is possible. My feeling is that the motor mounts might not line up, but you could cut and weld them and make it fit. Your swingarm might work because the swingarm bearings and spacers are the same between the two years I believe. You probably can use your front end, but will probably have to grind the steering stops a little to make it clear the frame. You would need some sort of oil tank. My thoughts are either buy one from a newer YZ250F, or rig up an oil cooler behind one radiator and use that as the oil tank also (you would have to have a way of draining the oil cooler when you do oil changes). The radiators won't fit, but if you are good at welding you can cut off the mounting tabs and weld them on in the right places. If all of these things work, then you would have to get a new subframe, gas tank, seat, plastic, and airbox. Looking at the price of all these parts used on ebay, it would still cost quite a bit more than to just sell your bike and buy a clean used 06. You have to remember, the newer bike will have better suspension and newer parts.
  • thumpyz
Posted February 06, 2008 - 05:18 PM
I see, I would rather just buy a newer bike, like you said, and get the new parts too. Thanks for the quick response KJ790, I appreciate it.
  • On January 15, 2017
  • 5 replies
  • Hot  28 replies
  • Hot  47 replies
  • Hot  113 replies
