What do you have to do to an 03 WR450F to make it Baja Ready?
8 replies to this topic
  • EGPeil
Posted February 06, 2008 - 03:56 PM
Just a curiosity question really. Considering taking an 03 YZ450F to Baja but might have to do a lot to it. Wondering if it might be easier to start with an 03-06 WR450F. Looking at those because I do have a lot of nice stuff for my YZ that I would want to put on the WR.
  • brad the best
Posted February 06, 2008 - 06:47 PM
big tank , good tires and chains , good fresh oil and coolant . everything greased . good lighting if your going at night .
closer to stock is probably more reliable . steering dampener would be nice .
  • tweav
Posted February 06, 2008 - 09:34 PM
Hey , you forgot to tell him that he should have a gun mounted on there somewhere. it's getting bad down there
  • brad the best
Posted February 06, 2008 - 09:36 PM
watch out for banditos . he's right .
  • EGPeil
Posted February 06, 2008 - 11:17 PM
Guess I should have mentioned that I am planning on running the 08 Baja 500 on my 03 YZ450F and I already have an IMS tank, Scotts steering dampner and a few other items. My concern centers around having an 18" rear and lighting capability. So if it is too expensive to convert a YZ450F maybe it is cheaper to ready a WR450F.
So more particularly - besides the 50 cal mounted on the bars - to power adequate lighting do you rewind the stator?, do you remove the battery? and if so what has to be done to facilitate that? Is the stock skidplate sufficient? Remove the speedo? If so what do you use to fill in the gap left by the speedo housing? Etc?
Rgds, Eric
  • tweav
Posted February 07, 2008 - 01:38 PM
I think I would just do up the yz if you already have it. gear it up , for more top speed.get one of these.
and one of these.
maybe a gps unit. and a good tool kit. and maybe a wr rear rim. It could be setup for under 1000 dollars , but it's not a winning setup.
that would be a good basic setup
  • EGPeil
Posted February 07, 2008 - 01:59 PM
Already checked with Rick - those stators don't work on YZs - only ELine has one for the YZs that are durable enough - $500. That is one of the reasons I have been considering the WR - more choices for HO stators not to mention they already have an 18" rear wheel. Not looking to win - just survive and finish. If I like it I'll start considering what it will take to compete next time. I am pretty sure though that I am just going to complete the build up on my YZ - everything will be reusable if I come back for other Baja races.
Thanks, Eric
  • taksx
Posted February 07, 2008 - 03:08 PM
Post you're question on the Baja forum. those guy's will make you're head spin with info.
  • tweav
Posted February 07, 2008 - 03:50 PM
think the only reason the that stator does not work on a yz is because your bike has an ac cdi and coil ,not dc like a wr . it would be fairly cheap to pick up a wr wiring setup . your yz has a more powerful engine and the suspention is better suited for your task . it's not a big deal to rewire a bike.
