Hot Hot Hot
9 replies to this topic
  • Thresher90
Posted February 05, 2008 - 11:15 AM
Started the XRR yesterday and it was running really HOT! So I shut it off and the overflow tank was about to over flow. :worthy: So I honestly have no idea what to do. Can these bikes get vapor lock like a car can? :busted:
Any help would be greatly appreciated. Thanks in advance.
  • Agent2
Posted February 05, 2008 - 11:29 AM
Corked, uncorked? How old? Stock t-stat / coolant? Any recent mods, crashes etc? A little more info might narrow down a possible problem.
  • Maroast
Posted February 05, 2008 - 11:51 AM
yeah, is that badboy corked up? If it is it will be running REAL lean...and thus REAL hot!!
Mine use to boil over before I uncorked it all the time...
  • Thresher90
Posted February 05, 2008 - 12:00 PM
Ya it is uncorked. Its a 2001 XR650R. No recent crashes and thats about it. I do know that I took the Radiator cap off the other day and its not the stock one.
  • Agent2
Posted February 05, 2008 - 12:42 PM
Were you riding or just letting it run? Dosen't take long to get hot without air flow through the rads. Water pump failures are rare, but do happen. The stock t-stats fail, but usually in the open position. Might want to do some basics -make sure the bike hasen't leaned out, Autozone has thermostats for a Suzuki Swift - part# 7203-180 (Motorad Failsafes) that fit the XR, you have to drill a weep hole on the flange. Drain the coolant, replace with 50/50 blend of non silicate and distilled water. Check the Rad cap, I believe Stant has one that fits, not sure of the the part #.
  • Maroast
Posted February 05, 2008 - 01:42 PM
Yikes! an uncorked XR about to boil over in Michigan in February...I'd seriously investigate this....
Like said before, drain the bike and check/change the thermostat first (they do usually fail in the open position though-->mine did)
While you got the coolant out, pull the cover and expose the water pump impeller....with the ignition off, use a piece of cord to tie the decompression lever in the the open position. You can crank the kick starter with your hand and assess the movement of the impeller. I would hold the impeller with my hand too while cranking it to determine if its slipping on the shaft.
Other than that I cant think of anything else to diagnose the problem other than flushing the lines to ensure patency. Good luck! and let us know what you find.
  • Thresher90
Posted February 05, 2008 - 01:55 PM
Ya I was letting it idle for about 10 minutes or so.
  • porterdog
Posted February 05, 2008 - 03:23 PM
That's your issue right there. Wouldn't worry until it starts doing that while you're moving.
  • Denn10
Posted February 05, 2008 - 03:52 PM
10 minutes to idle, theres no reason for a bike to idle for that long. No airflow means its gonna overheat.
  • Thresher90
Posted February 05, 2008 - 04:04 PM
Thanks guys ill be sure not to do that again :busted:
  • 3 replies
Which thumper motor for a street tracker? by woz
  • Hot  29 replies
Honda XR650L 2016
  • 0 reviews
  • Hot  28 replies
Washington
  • Hot  32 replies
