Supermoto Wheels with Cush Drive
5 replies to this topic
  • Appalachian DR
Posted February 05, 2008 - 04:00 AM
I'm looking for any leads to a source for 17"s for the 03 WR with a cush hub.
Thanks
  • tweav
Posted February 05, 2008 - 04:06 AM
call these guy's they can hook you up , with whatever you need as far as supermoto stuff goes.
http://www.factorypr...g.com/index.htm
  • Appalachian DR
Posted February 05, 2008 - 12:35 PM
They only list hubs and wheels for the YZ.
Does the YZ and WR use the same wheel?
  • tweav
Posted February 05, 2008 - 01:02 PM
the yz and the wr share the same rear hub . the front hub on a wr has two tabs that drive your stock odometer/speedometer , other then that the hub is the same . you can ether have your front hub relaced , or what most people do is just pop on a aftermarket computer like a vapor .
So yes yz stuff fits mostly . I don't think any aftermarket front hub has the two tabs .
  • MaxPower
Posted February 06, 2008 - 01:37 AM
[COLOR="Green"]I read that a clutch basket from a 450 quad will fit these bikes.That has to absorb some of the road shock instead of using a cush hub. They have a spring dampening set up in the big gear behind the basket. I bought one but havent installed it yet.[/COLOR]
  • tweav
Posted February 06, 2008 - 09:51 AM
ok here is some links to gytr parts , they don't say anything about a damper. but they are not the same looking at the pics. by the looks of it you need something in the middle of the 4 wheeler one to make it work
wr 450f
http://www.yamaha-mo...0/0/detail.aspx
yfz450
