asv lever set up
2 replies to this topic
  • blown351gt
Posted February 04, 2008 - 11:50 AM
I have a 2006 wr450. I am looking at getting the asv c-5 series clutch lever and clutch perch with hot start and brake levers. I am reading there is no fitment for the perch with hot start, but is there anything I can use with replacing the perch, lever and hotstart?
I am also looking at the msr pro raptor clutch lever and perch with hot start. any info would be very nice
Thanks
  • surfnewman
Posted February 05, 2008 - 02:16 PM
The only reason it says that it will not fit is because there is a shutoff switch that will not let the e start work without the clutch engaged. You can disable this and use the universal lever perch and hotstart.
  • blown351gt
Posted February 05, 2008 - 03:29 PM
so I can just use the asv c-5 perch with hot start if disabled? How can I tell if it is already disabled? I bought the bike from a stunt rider and he has a cut msr clutch lever and perch on it with no hot start hooked up.
