Question about 650R and 650L Hubs
6 replies to this topic
  • PDXCHRIS
Posted February 02, 2008 - 09:31 AM
Can anyone tell me if the Hubs of a 650R will fit on a 650L
Thanks
  • dylanr
Posted February 02, 2008 - 06:38 PM
you should consider putting more in the title than just "question", youll get more responses, im not sure if theyre the same, sorry
  • martinfan30
Posted February 02, 2008 - 10:09 PM
Put a little more info into the title just to get the users attention. There will be some that will just pass on your post., only because they see " ? ".
Those that pass may have the answer you need...
  • bigredpig
Posted February 03, 2008 - 01:13 AM
I don't think so but i think the 400s are the same? any one?
  • evomx971
Posted February 03, 2008 - 05:20 PM
I'm 99% sure the front is the same (different size brake rotors though). The rear is definitely different.
  • absynth01
Posted February 04, 2008 - 05:19 AM
Depends how much work you want to do. The rear axle sizes are different. The actual rim setup is the same size. As for the front, I found a lot of hondas do bolt up. My CR,and all 3 XR'S fronts swap. You do need the proper spacers to take care of the rotor side. Easy turn on a lathe. The speedo side needs the same adjustment for the non speedo rims. Actually the CR spacers worked, I just used two from the speedo side and it fit.
As for the rears, you could shop a different inner bearing race to match the smaller 650L axle. I have'nt decided to fully swap my CR rims yet, but it looks fairly easy to get the correct spec bearing. You do have to use the L shaft, or you'll be drillin your swingarm. Anyone try swapping a CR rear for a 650R rear yet? They look close.
  • PDXCHRIS
Posted February 04, 2008 - 04:10 PM
Thanks Guys this really helps.
  • 7 replies
Honda XR650L 2017
  • 0 reviews
  • Hot  28 replies
Which thumper motor for a street tracker? by woz
  • Hot  29 replies
  • 22 replies
