FastLine Brakeline - Tips and Ravings !!!!
1 reply to this topic
  • The_Missile
Posted October 21, 2002 - 06:04 AM
Well, my stock was toast - the braking was horrible and I could see the line 'bulging' so I got me a bona-fide fastline brake line (only for pros! so I knew it was for me :D)
I ordered the WR version and it actually came as a WR replica taking the routing the origional did. Its a nice blue and (purple :)) color.
Cost about 67$ if I remember well + shipping.
Installation was easy once I figured that the bend on the caliper end is different than the stock and that even though my bolt was tight, the conncetion wasn't...a few drips of fluid later and 2 additional crush washers as "spacers" saw me fine. Beware of this on installation I puzzled for a while before figuring it out.
Up top I had to route the bend at the master cyclinder a little more vertical than stock, but what the hey, it works just fine and is atill protected.
A couple of squirts on the mity-vac (essential for no pain prging) and some help from my wife and the thing was squared.
The result ..... braking is a whole new experience. One finger braking will put me over the handlebars if I'm not careful. Awesome.
  • MN_Kevin
Posted October 21, 2002 - 06:28 AM
When I installed by Brakeline WR Replica SS line, I looked long and hard at each end.
I remember Clark Mason said he had to grind some off of his fittings to get it to fit tight.
As I studied it, I realized common sense did NOT apply. I flipped it around, and the fittings were absolutely leak free.
Initially, the angle and shape of each end promoted me to attempt to fit it on backwards...
