DeWhat's a decent price for new '04 YZ450F?
10 replies to this topic
  • rdefonce
Posted February 01, 2008 - 04:08 PM
I'm impatiently waiting for fuel injection on YZ strokers, but in meantime I'm thinking of filling gap between my old '99 400F with something a bit newer/lighter/etc. but less expensive than new '08s.
A couple questions:
Is the 2nd year 450 (2004) a decent year?
and,
Local shop has new leftover 2004 YZ450F . . . what would be a fair "out the door" price for it?
Posted February 01, 2008 - 04:44 PM
That's a tough one for everybody. Since you can go get a really good used '06 for $3500 or so, and clean used '03-'05 YZ450's go for as little as $2000, even a new '04 isn't worth much right now. If he holds it for 10 years, it will probably be worth more, but as it is, I'd guess it's worth $3000. I'd also guess he won't take it.
  • rdefonce
Posted February 01, 2008 - 08:33 PM
Whoa, only 3k??? :-o
That surprises me. I agree, no way he'll take that.
I would pay a grand over that for a new bike . . . maybe he'll take that.
I'm leery about used though, don't know what they've been through even if they appear clean.
Silly as it sounds, one reason I want the steel-framed 450 is ease of re-jetting; it's easy to get to carb! I was talking to locals with aluminum framed bikes and to re-jet they said removing shock, then removing carb was easiest method!
Is that true?
Posted February 01, 2008 - 11:31 PM
No. Removing the carb is significantly more difficult on the new bikes, but you don't need to remove it to rejet. It can be done without moving it at all, with the right tools.
http://www.thumperta...028#post5323028
http://www.motionpro...s/fcr_carb_tool
A 1/4" ratchet and socket help to loosen the main jet.
  • rdefonce
Posted February 02, 2008 - 07:33 AM
Good info, this!
It appears the tools will work for main or pilot jet.
I don't see anything about needle clip position change though, which is a likely change (at least on my '99 for my altitude/temps had to go 1 clip richer than stock) Access to clip change is top of carb . . . perhaps I could get to that without rotating/removing carb.
Posted February 02, 2008 - 09:24 AM
That you can do fairly easily as soon as you accept the fact that the top engine mounts (head stays, if you will) have to come off. Then, the top of the carb is pretty easy to get at. Pulling the stays isn't hard at all. Trying to work around them is just miserable.
  • MX1967
Posted February 02, 2008 - 07:49 PM
After reading MXA'a test of the FI RMZ450 I wouldn't buy a FI anything until the factories do more testing, & I would NEVER buy a 1st year model FI bike. They said it has the power of a "RMZ 350". There is nothing wrong with the FCR carb on the newer bikes. My 06 runs perfect.
  • BBrown626
Posted February 02, 2008 - 11:13 PM
Gray,
have you used the Motion Pro set? I was considering it for work on my son's '07 250f.
thank you.
Posted February 02, 2008 - 11:30 PM
Yes, I bought one to try, and it's helpful. You'll still need a 1/4" ratchet and a 1/4" socket to use for breaking the jets loose (the pilot jet screwdriver bit fits in a 1/4" socket). The rubber liner on the knob needs to be glued in place, too.
  • rdefonce
Posted February 03, 2008 - 08:30 AM
That's not so bad; I just got done with adjusting valves on my 400F (for the first time in it's life since new, although I've checked them many times; finally they needed adjustment!!) and removing the head stays was definitely the easy part of the job.
Perhaps I can find a leftover new '06 for a decent price . . .
mx1967, I'm waiting for the 2nd year FI YZ's, for the reasons you stated.
  • MaxPower
Posted February 04, 2008 - 03:57 PM
[COLOR="Green"]Getting a steel frame YZ cause its easier to jet? The bikes arent that finicky. You are going to ride the bike more than you are going to be jetting it. The 04 YZ450s were so big,go for the new aluminum frame. [/COLOR]
  • On January 15, 2017
  • 9 replies
  • Hot  36 replies
