Changing Radiator Cap. Bottle?
4 replies to this topic
  • levy1
Posted April 14, 2002 - 10:09 AM
I am a little worried about the heat of my engine running my new 13-1 compression piston. I want to know what cap to run for a cooler engine and why are you guys taking off the overflow bottle. Before any of you spank me I was a good tt’r and read the archives. Most seem to be using a 1.6lb cap from the KX500. Sounds good but why take off the bottle. It doesn’t appeal to me and if I get lost in the woods I might need a drink. Can I make the change without removing the overflow bottle? Is the KX500 cap the one?
[ April 14, 2002: Message edited by: levy1 ]
  • MN_Kevin
Posted April 14, 2002 - 12:13 PM
"They" remove the bottle to reduce weight.
For slow woods riding, I don't think I'd go without mine...Taint worth it.
  • SFO
Posted April 14, 2002 - 12:34 PM
I run a 1.8 cap from an '01 kx65 on my 14 to 1 444cc engine.
I don't run the resevoir and have never had an issue.
I have gotten caught in some snotty terrain too.
  • levy1
Posted April 14, 2002 - 12:41 PM
Wow! 14-1 with 444! ~ I thought I was a power freak. Now I must change my profile because I see there is a bigger dog out there. Can I sit on your porch?
  • SFO
Posted April 15, 2002 - 04:38 PM
Levy,
Sitting on my porch could be considered spam.
I also pulled 60 grams out of my first 97mm piston and pin.
When all yur freinds ride 520's it's time to build an underdog!
Next I am planning to dyno test the new Web cam grinds and the new Hot cams.
This along with a big valve head...
