426 piston/rings
3 replies to this topic
  • soco3594
Posted February 01, 2008 - 01:31 AM
Ok so Ive had my 426 for a week or two and notice that it leaks oil from the breather hose and is a little lumpy at steady throttle. It still starts first kick and goes hard under full throttle, but the bike is going on 7 years old so I would expect that it would be near due for a rebuild considering the symptoms and I know that last owner didnt do any work to it. That said, I am dropping it off to my local guy to check the jetting (Im still a bit inexperienced), but if he finds that jetting won't cure it then Id say I will be looking at a piston and rings, hopefully no more.
Does anyone know roughly what I would pay for a new piston and rings?
  • SRT426
Posted February 01, 2008 - 01:43 AM
Do a leak down check before tearing anything apart, that will give you a good clue as to how well the rings and valves are sealing.
Here is a chart for the YZ426 for jetting, I imagine it's pretty close for the WR as well and will get you in the ballpark so you can fine tune it.
http://motoman393.th....426jetting.xls
  • matt4x4
Posted February 01, 2008 - 04:15 AM
Breather tube drips is NORMAL, sounds like Jetting - I think your bike is probably fine, compression test it, check your valve clearances and if those come out fine, ride it like you stole it - We all do.
  • soco3594
Posted February 01, 2008 - 12:16 PM
righto cheers guys. As I said im a bit inexperienced with the mechanics of the bike since Ive only had it for a week or two so Ill drop if off to my mechanic and ask him to do a compression test and sort out the jetting and hopefully that will make a difference. From what I can tell there is plenty of compression at TDC. Also the altitude where I live is a couple of hundred metres higher than where I bought the bike so Id say it wants rejetting anyway.
thanks for the advice
