warped rotor question?
2 replies to this topic
  • Bamster
Posted April 14, 2002 - 02:29 AM
While installing a new tire I noticed I had a slight warp in my rear rotor. enough to wear my iner pad a little more than the outer and enough
to make the caliper float back and forth a couple
mm's. Can this be staightened or do I need a new rotor or I just live with it? How much is a new rotor? Thanks in advance
Scott
  • Woodzi
Posted April 14, 2002 - 05:36 AM
You can straighten them using an adjustable wrench if they are not bent too badly.
  • MOmilkman
Posted April 15, 2002 - 05:41 AM
I bent my front rotor some time ago and I tried and tried to get it straight but I finally decided it was a lost cause.
I just decided to live with it since it dosent wear pads prematurely.
