WR400F valve clearance tolerances.
6 replies to this topic
  • Fletch 2
Posted January 29, 2008 - 12:54 AM
Hullo,
could someone please give me the valve clearance tolerances for the 2000 model WR400, i dont have the yamaha manual to look these up so any help would be great.
Cheers,
Fletch.
  • creeky
Posted January 29, 2008 - 05:18 AM
'00 WR400F clearances for cold engine. Intake: .02mm (.0059-.0079") Exhaust: .03mm (.0098-.0118"). If you are going to do a valve adjust, I strongly recommend that you get hold of a service manual, otherwise you are working in the dark.
  • byggd
Posted January 29, 2008 - 05:22 AM
Fletch. Here is a site from down under where you can get the manual for free! :busted:
http://www.yamahaown...ook.com.au/?r=0
  • matt4x4
Posted January 29, 2008 - 05:39 AM
you can get your manual downloaded from here
http://www.yamahaown...GS-28199-30.pdf
Intake:0.15-0.20mm
Exhaust:0.25-0.30mm
Creeky - good call I think your imperial ones are good, but the metric are a couple of decimals off, they don't even make shims to those tolerances
  • SXP
Posted January 29, 2008 - 06:37 AM
The metric portion of the below quote is NOT right; however, the english part is correct:
This is the correct metric spec:thumbsup:
Intake:0.15-0.20mm
Exhaust:0.25-0.30mm
  • creeky
Posted January 29, 2008 - 11:17 AM
Intake:0.15-0.20mm
Exhaust:0.25-0.30mm
You are absolutely correct MATT4x4 and SXP, don't know how that extra zero got in there, senior moment I guess. Aplogies to all.
  • Fletch 2
Posted January 29, 2008 - 11:39 PM
Thanks for that. Cheers.
