2 Master Links?
13 replies to this topic
  • mmbasa
Posted January 27, 2008 - 04:11 PM
I cut my chain 1 link to short, can I use 2 master links?
  • 642MX
Posted January 27, 2008 - 04:13 PM
Of course you can. :cool:
Posted January 27, 2008 - 04:27 PM
I had two links in the chain on my '03 for over two years without a problem.
  • ktmdestroyer
Posted January 27, 2008 - 04:28 PM
yep :cool:
  • mmbasa
Posted January 27, 2008 - 04:47 PM
Sounds good to me, thanks for the speedy replies.
  • todds924
Posted January 27, 2008 - 05:00 PM
I would like the extra link to be a rivit link though.
  • tnl
Posted January 27, 2008 - 06:22 PM
I just bought the motion pro rivet tool and want to rivet my master link. Does the new rivet have to be a special type pin for this application or can an old one be used that has been pressed out? I believe that a new one (special kind I don't know). I don't think you can just rivet the master link? I have a Regina orn6 chain.
  • bignick
Posted January 27, 2008 - 06:25 PM
+1
Also a tip from roadracing, use silicone sealer and coat the clip and use safety wire to keep the clip from working its way off.
  • tnl
Posted January 27, 2008 - 06:36 PM
What guage wire?
Posted January 27, 2008 - 07:49 PM
The master link must be of a type originally intended to be riveted. You cannot rivet a clip type because the ends of the pins are hardened. Furthermore, the master link must precisely fit the chain it's used on.
The rivet type master link for an ORS6 may fit. The TT store lists them if you can't find them elsewhere.
I will say that the clip type master on the ORN6 is an exceptionally strong, impeccably reliable piece when correctly installed, and I would not hesitate to use two of them on my own bike.
  • King_Air
Posted January 28, 2008 - 04:17 AM
Can you run the two masterlinks next to each other, or should they be spread apart?
  • USED YZ426F
Posted January 28, 2008 - 06:12 AM
You can run them next to each other or with some links in between.
If you are using the proper link and installing them correctly, you won't have a problem.
Posted January 28, 2008 - 07:25 AM
Mine were right next to each other for over two years.
  • Wes Woodin
Posted January 29, 2008 - 01:03 PM
I second that!:busted:
  • 10 replies
  • On January 15, 2017
  • Hot  36 replies
  • Hot  50 replies
