Loss of power 2007 kx250f
6 replies to this topic
  • oceantrav
Posted January 27, 2008 - 01:22 PM
I just changed my oil, and after the first ride i realized it was a tad to low. So i just poured some more in without measuring it, so then the next ride "today" it ran like shit, and i realized there was way to much oil, so i drained some out till the level was in the middle of the view window. So then the next practice i go out and it still runs crapy??? When i say crappy i mean it doesnt have all the power there that it usualy has, i was coming up short on jumps i can clear no problem usualy. Has anyone ever heard of this, it might have nothing to even do with the oil???
  • radio592
Posted January 27, 2008 - 01:47 PM
bad batch of gas? dirty carb/air filter/fuel filter? uhh what else is there, top end worst case?
  • DGRAHAM
Posted January 27, 2008 - 02:10 PM
yeah too much oil usually will fix it's self, like blow it out all over your bike. but unless you filled it up all the way it would be hard to make it loose that much performance? probably something else
  • dirtride858
Posted January 27, 2008 - 07:41 PM
ya, the oil level won't make your bike slow, maybe you got some dirt in your airbox when you changed your air filter and it clogged your main jet. I would clean out your carb first and see if that fix's it.
  • crrider491
Posted January 28, 2008 - 11:22 AM
sounds like the same thing that happend to me. I cleaned out my jets and it ran perfect.
  • oceantrav
Posted January 29, 2008 - 06:42 AM
it turned out that im just an idiot! The problem was that my grips were extremely loose, so when i got on the the throttle it was slipping, and i thought i was loosing power. Ya, i know im stupid.
  • dirtride858
Posted January 29, 2008 - 07:29 AM
be carefull! if your grip slides off your bars, you could wreck really really bad... I've seen it happen in mud conditions. Thats why some people use safety wire on their grips.
2016 kx250f bogs when upshifting by Eric556
Dirt Bike   Dirt Bike Technical Forums   Intake - Jetting / Fuel Injection
2013 Kx250f wide range gearing by got2haveit909
Dirt Bike   Special Interest Forums   Dual-Sport/Adventure
  • 0 replies
Youtube Channels by CodyR
  • Hot  298 replies
Opinions Needed for Service Plan by Holeshot1982
  • Hot  44 replies
Moving to thumper? by 2StrokeCruiser
  • 10 replies
