I wanna clear something up....
13 replies to this topic
  • dldavis_66
Posted January 26, 2008 - 06:41 PM
I recall reading a few articles regarding the installation of smog blocking kits online that really ticked me off saying that the doohickey that looks like a lawn sprinkler, located below and to the rear of the fuel petcock, or just in front of the compression damper cylinder, is a "charcoal canister".
Well that doohickey is definately NOT a charcoal canister, heck it doesn't even have anything to do with smog!!! I don't know where these :cool: come off saying to take it off for the installation of a smog block kit AND to cut/shorten the hose to fit from the Tranny breather outlet to the Air Box. That's just plain stupid:thumbsdn: , unless of course, you want to suck a lot of oil into your Air Box. For all intent and purposes, that doohickey is in fact a Oil/Air separator. It helps to minimize the amount of oil getting sucked into the Air Box!!! They even need to be cleaned out every now then, depending on riding conditions, because they can and will fill up with oil if left alone too long.
I'll tell you what IS a charcoal canister though: that doohickey at the front/left of the motor, just a few inches below the left exhaust pipe. It's just a smaller version of many of the vapor collection canisters that you find on automobiles AND is smog related.
Just wanted to air it out.
All the best to everyone here at Thumper Talk.
  • weskc35k
Posted January 26, 2008 - 08:20 PM
Good for you.
  • Bibleman
Posted January 27, 2008 - 05:07 AM
Thanks for the info. I noticed that the air box has a short crimped rubber tube at the bottom that also looks like it's designed to allow excess oil drain out. Maybe it's a back-up measure.
  • martinfan30
Posted January 27, 2008 - 08:19 AM
Ok, take a breather!!
When I eliminated my smog and airbox, I ran a line from the crank breather nipple to just under the rear of the tank with a small K&N crank breather filter.
  • dldavis_66
Posted January 27, 2008 - 11:16 AM
Well, I do admit that I was rather P O ed when I started this thread. But, not at anyone here at TT. I mean the thought of people getting online and putting out misinformation really bugs the heck out of me and I'm sure many others too.
I'm not sorry for what I wrote. I am sorry if I offended anyone here on TT,especially to the guy who gave me a neg rep(I really do not need to know who you are). Any offense was definately was NOT intended.
All the best to everyone here at TT.:cool:
Sincerely,
David
  • Old Dog
Posted January 27, 2008 - 11:42 AM
I did the exact same thing. :applause: :cool:
After a full season of riding I noticed that it gets kinda cruddy looking, so now I change mine every spring. I also noticed that having a setup like this seems to help keep my oil cleaner longer (uncontaminated by water, etc.). :busted:
  • scalejockey
Posted January 27, 2008 - 11:49 AM
Just the fax and only the fax.:cool: thanks..
  • martinfan30
Sincerely,
David
No need to appologize. Misinformation is a bit of a problem at times. I only think the term "char. cannister" is used for that part only as a general term.
Thank you for clearing this up, many will benefit.
  • martinfan30
Posted January 27, 2008 - 11:50 AM
I did the exact same thing. :busted: :cool:
After a full season of riding I noticed that it gets kinda cruddy looking, so now I change mine every spring. I also noticed that having a setup like this seems to help keep my oil cleaner longer (uncontaminated by water, etc.). :crazy:
Great minds think alike! I also noticed my oil looks damn near new after 1k. miles. :applause:
  • Bibleman
Posted January 27, 2008 - 05:06 PM
If I'm not mistaken by connecting the breather tube to the airbox you're getting filtered air, so how would the oil stay cleaner with a separate filter on the end of the tube?
  • Old Dog
Posted January 27, 2008 - 05:23 PM
I've wondered the same thing myself Bibleman. :cool:
The nearest I can figure is that because it's a smaller dedicated filter as apposed to using a bigger shared filter that's enclosed in a box (the air box), it doesn't get the same condensation/moisture build up.
All I know for sure, is that my oil is definitely cleaner using this setup than it was before when it was hooked into the stock setup. Plus, I like the fact that it's tucked up in under the tank, making it higher from the ground (or water if you're crossing a brook, stream, river, etc.) and less likely to let water into you're crankcase if you dump your bike in water, or get in some pretty deep going. :applause:
  • XR650L_Dave
Posted January 28, 2008 - 08:44 AM
When possible, I've tried to gently correct those that called it a charcoal canister.
One useful thing about having it off- can turn the carb to get to the jets!
Dave
  • Motosprtman
Posted January 28, 2008 - 09:12 AM
so now should I re-install it, and if so what are the connections?
  • Rockjockey
Posted January 28, 2008 - 09:50 AM
Bibleman, it just takes the crank case breather up higher than the air box in case you encounter deep water. Some prefer it having its own filter, some dont.
  • Hot  29 replies
  • Hot  60 replies
  • 17 replies
  • 3 replies
  • 4 replies
