KX 85 & 100 rider weigh in
Posted 26 January 2008 - 06:20 PM
Posted 27 January 2008 - 06:35 PM
Posted 27 January 2008 - 06:41 PM
bangmika said:
Get a crf150r.
Much better for a play bike, trust me i had one, just sold it though to get a 250.
you will regret getting the 85/100
Posted 27 January 2008 - 06:45 PM
Get a 250 beater or a 70's 350 or something to play.
Posted 27 January 2008 - 07:04 PM
I weigh 145lb 5'5", w/out gear. I have my son's KX100 setup for me right now, and I'm using FC heaviest KX100 springs for my weight.I think .33 fork springs, and 5.3 shock spring. I'm getting 80mm rider sag, and 22mm static, (ideal is 75 rider/25 static) w/ about 5/8" spring preload. My son's setup at 95lbs w/out gear and at 5'0" uses a second shock, lowered w/ an 8mm spacer, stock springs. I like his setup better than mine because it's quite a bit more soft and now having put on the firmer springs on a stock length shock, I like to put back his setup for riding the rocks. an 1" lower on the suspension, I can dab here and there , and this makes riding extreme rocks w/ stair stepped stuff feel like a walk in the park on a 150lb bike. btw, I am also using Renthal mini-hi 7/8 handlebar, which is 3" taller than stock bar. Even my son has no problems w/ this taller bar, which IMO is indicative that the stock bar is just too low for most riders.
A crf150r is nice, and you'll pay 3-4x the price for a newer unit vs. a good old used 2stroke KX100 that hasn't changed since '97. But if you weighed 150+, you don't really have many choices, as the thumper puts out more torque to pull your weight.
But you can find tons of KX100 used for anywhere as low as $900 (needs work) to '03-'05 KX's (ready to ride) for up to $1700. Also, KX100 shares parts w/ KX85. So Aftermarket support is abundant and extremely affordable. On ebay, they're selling NEw KX85 (AND SOME kx100) parts off '07's that have never even touched dirt! It's a regular thing now. someone's figured out that there's money to be had buying a new bike and selling the parts. There must be enough fat in the whole thing because I bought a brand new clutch basket off a KX85 for $65, brand new '07 shock w/ new spring for $100.
ANd if he's still selling brand new parts at those prices, his profits must be good.
Bought an oversize 2.4 gal gas tank used on a KX85 for $85.
Posted 28 January 2008 - 06:08 AM
Posted 28 January 2008 - 08:19 AM
The 85 has Stock engine with pro action suspension on it. and it moves pretty good with me on it.
Posted 28 January 2008 - 01:28 PM
impulsepaintballer said:
The general rule of thumb is: Can you sit on the bike and start it yourself? Can both toes touch the ground?
Posted 28 January 2008 - 02:38 PM
Posted 28 January 2008 - 03:05 PM
bangmika said:
Dude, you can set up an KX85 or 100 as a play bike for any weight. Hell they set up 50's and 110's for adults. You are starting with a mx chasis which is made for racing. Our mx club started an "adult 85" class for fun and it's a blast, you just have to set up the bike.
Suspension obviously is most important, I went with 38kg springs in the forks 10 weight oil and a 5.6 rear shock spring. This will get you close to play. There are lots of options here including revalve if your really serious. I got my springs and suspension work from cannon racecraft (springs) and house of horsepower for suspension tuning. They know how to set up these bikes.
have fun..
Posted 28 January 2008 - 06:02 PM
Posted 28 January 2008 - 10:03 PM
Posted 28 January 2008 - 10:39 PM
NiceUserName said:
thats what I thought. The peak power is pretty stinking high too. Pretty close to my yz250 4t stock. And since I always seem to be juicing the motor, I'll be on the pipe.
Posted 28 January 2008 - 10:44 PM
crf150f guy said:
But the way I see it a KX-motocross race bike for kids. KX with and adult on it=play bike. six gears on the pipe and mid 20 HP. It should rip my friends klx 143 apart.
Posted 29 January 2008 - 05:05 PM
Posted 30 January 2008 - 03:16 PM
MXkid714 said:
It depends. if you're kahooneys are developed enough, and you're tall enough you could ride a 250F. Gotta try a 100 out first if possible offroad, not down the street at the dealership.
Posted 30 January 2008 - 04:38 PM
crf150f guy said:
Every kid wants a MX bike!
Go for a KX!
