Steering stem nut..special tool?
4 replies to this topic
  • atitagain
Posted January 25, 2008 - 12:46 PM
Well, it's cold and wet here in Phx this weekend (60F BRRRR ). I have decided to grease the steering on my 07 WR450 for the first time...I know, I know :crazy: "You should grease them right away". :applause: Do I need a special tool to remove and re-torque that funny looking nut on the top of the stem? Is there a common tool that fits it?:cool:
Thanks for your comments :busted:
  • bhiggins25
Posted January 25, 2008 - 02:12 PM
While special tools are made for this purpose, most just use a good-sized flatblade screwdriver and a rubber mallet to loosen it up. A few light taps should do the trick - they are not torqued very tight at all.
  • bg10459
Posted January 25, 2008 - 03:21 PM
The proper tool is a hook spanner, but very few, if anyone, actually use them. The spec for that nut is about 5 ft lbs; not very high.
When you re-install everything, tighten that nut real good to seat the bearings and then back it off until you just start to feel play in the steering stem. Then make it hand tight and then turn it one extra notch with whatever mechanical advantage you like.
  • byggd
Posted January 25, 2008 - 03:26 PM
Sounds like perfect riding weather to me! :cool:
  • drumurr
Posted January 25, 2008 - 03:44 PM
