Possibly a cheaper solution to carbeuration woes
4 replies to this topic
  • Ironbeak
Posted October 17, 2002 - 07:08 PM
I currently own 2 Hondas - an XR650R with street tires for eating up the canyons and a Shadow 1100 Aero for touring. Anyway, a commonly known solution to carbeuration problems among Shadow riders, particularly those on Hondashadow.net, is a product called Dial-A-Jet. It's made by Thunder Products. Here's a URL to the Hondashadow.net forum search page.
http://hondashadow.net/forum.php
Do a search for dial-a-jet or just "daj" for short. It sounds pretty interesting, and I don't see why it wouldn't work for an XR650R.
Dial-A-Jet only costs about $120 or so and supposedly enables you to instantly adjust your jetting situation to compensate for bike mods in addition to changes in elevation. It's also said to smooth out throttle response and actuall INCREASE fuel economy. (Weird.) The Edelbrock Quicksilver carb seems too expensive to me, and Dyno'ing the stock carb ain't cheap either.
You can check out Dial-A-Jet by going to Thunder Products' website at: http://www.thunderproducts.com/
If anyone has any thoughts on this idea, please reply.
  • qadsan
Posted October 17, 2002 - 08:11 PM
The Dial-A-Jet is an interesting product that's been around a while and probably more common in sled applications where higher engine RPM is more common for longer periods of time. I've heard good things about this product for sled applications, but I haven't heard too much about it for quite some time in off road motorcycle applications. Varner Motorsports also has a similar product. There's also the Holtzman Variflow that works a bit differently in that I recall it adjusting float bowl pressure based on barometric pressure changes to acheive similar results as opposed to using an adjustable jet. All these products are interesting and may provide some value, but jetting a carb to work well isn't that hard to do if you have a good baseline to work with. Once you know what jetting works well for your bike, you can apply correction factors to determine your needs based on your riding environment. If you're going to be riding at altitudes of plus or minus 3000 feet from your normal riding locations, then something like this might be handy to quickly tune your bike.
These types of products are in a different category than the Edelbrock as they don't provide an internal fuel cell for consistant fuel delivery under demanding conditions and easier starting if you dump your bike, nor do they offer a pump shot for improved low end throttle response, etc.
If you're solely looking for an easy way to keep your bike tuned well without changing jets, then these products might be what you're looking for. If however you're looking for improved low end throttle response (better than the stock carb can offer), easier starting when your bike is dumped, etc, then you may want to look more seriously at something like the Edelbrock.
  • Serpexc
Posted October 21, 2002 - 06:39 AM
How about an FCR Keihin, or an HSR series Mikuni? I think flat slides pumpers are better than CV type carbs in the dirt, not my experience, as I haven't owned a CV carbed bike for the dirt.
  • qadsan
Posted October 21, 2002 - 08:05 AM
They're also good products too. The CV carbs seem to work pretty well for certain applications from talking with others, but the concept doesn't appeal to me for off road use with all the pounding a dirt bike or quad takes. Seems like the slide would be fighting the G's if the bike/quad was used agressively.
  • motometal
Posted October 27, 2002 - 03:48 AM
I agree in theory. doesn't the Yamaha Raptor (quad) have cv carbs? It's off road only...
  • 3 replies
  • 4 replies
  • Hot  29 replies
  • Hot  35 replies
  • 9 replies
