08 450, doing my first valve check, any tips?
10 replies to this topic
  • soudry
Posted January 24, 2008 - 08:09 PM
i saw an article on here about checking valve on a yz250f 06, is it about the same procedure?
just looking for any help that the menual wont tell me,
btw.. do i need to empty the oil b4?
thanks again, and have a good one:thumbsup:
  • 642MX
Posted January 24, 2008 - 08:12 PM
http://motoman393.th...ech/valves.html
Posted January 24, 2008 - 08:24 PM
No, you don't.
  • Slinkyman16
Posted January 24, 2008 - 09:16 PM
Heres a tip...
Go out and buy a new hot start nut.. the facotory plastic peice sucks and 99% chance you will strip it trying to put it back in..
  • YamahaThumper
Posted January 25, 2008 - 12:18 PM
Heres a tip...
Where did that come from? He doesnt have to remove the hotstart nut, being that its on the carb.
Good advice, but I cant relate the two?
  • Slinkyman16
Posted January 25, 2008 - 12:53 PM
if you read the owners manual it actually tells to you to remove the hot start cable from the carb. It gives you a bit more clearance to remove the valve cover..
I went by the manual the first time i ever checked my valves and i learned the hardway that it was a bitch to put back.
Posted January 25, 2008 - 02:45 PM
Well, it does also reduce the risk of breaking the aforementioned, ridiculously fragile nut, but you have to watch out for manuals sometimes. They used to tell you to drain the coolant and remove the right radiator, too.
  • soudry
Posted January 25, 2008 - 03:04 PM
thanks guys. i'm going to to it this weekend being that its kinnda cold
  • sidewinder2
Posted January 26, 2008 - 09:34 PM
Zip Ty has a red anodized hot start nut. Got it on my WR and soon on the
YZ!:cool:
  • Wes Woodin
Posted January 27, 2008 - 06:15 PM
Heres a tip...
I've had mine on and off 5-6 times, and the plastic one is still great!:cool:
  • YamahaThumper
Posted January 28, 2008 - 05:51 AM
Same here, just use the right size wrench and you should never strip anything :applause:
Disclaimer: I said should! :busted:
  • Hot  36 replies
  • Hot  47 replies
  • 10 replies
  • Hot  50 replies
