Someone stop me, quick!!!!!!!
54 replies to this topic
  • sploogemonkey
Posted January 25, 2008 - 11:08 PM
#41
I thought about mentioning the idle as well but I'm always afraid of insulting someones intelligence.:busted:
Man, insulting my intelligence is old news, don't even worry about it! I ain't ashamed to admit that I'll take all the help I can get! :applause:
Today was another busy day that I couldn't find time to mess with the bike. I'll try the idle adjustment thing tomorrow and see how it goes.
Thanks for the tips. :cool:
  • Doofus007
Posted January 25, 2008 - 11:19 PM
#42
+1 on the idle being too low. The same thing happened to me recently, had my suspension revalved and during the takedown I guess I loosened the idle screw. Prior to removing the suspension my bike (96' XR600 68 pilot,158 main) would start 1st or 2nd kick. When I out it all back and tried to start it wouldn't go. I knew I hadn't done any motor mods so I was scratching my head(after several vulgar outbursts) and recalled the idle screw. Show nuff', it kicked right over when I idled up. Try it.
  • weskc35k
Posted January 26, 2008 - 05:03 AM
#43
Do it pop on decel,68 pilot would be a bit small i'd think unless your at elevation.
Oh and the idle thing as well.
  • scalejockey
Posted January 26, 2008 - 07:41 AM
#44
I had one do this years ago.Try a leaner float level, the float might be sinking a little.
  • onebigmike
Posted January 26, 2008 - 04:03 PM
#45
I'll give ya a hundred for it if you are that pissed at it.(before you shoot it)
I'll give ya a hundred and fiftey. Definatly BEFORE :cool: you shoot it....
  • sploogemonkey
Posted January 28, 2008 - 04:29 AM
#46
It's fixed! Woo-hoo! :prof: :p
And to all of you that offered advice.... :cool: :eek: :lol:
I honestly don't remember what fuel screw setting I ended up at (I'll check it later), but the idle setting apparently was the trick. :worthy:
I took kawabuggy's (and others) advice and turned the idle up about 1/2 turn, and it started on the second kick.:applause:
The exact routine was:
  • Kick 3x with decomp lever engaged (to prime cyl.).
  • Full choke
  • Release decomp lever and slowly kick until I feel compression build.
  • Engage decomp lever and kick about 10 degrees past TDC.
  • Release decomp lever and bring kick lever to top.
  • Kick like ya got a pair!
Once the bike has warmed up, I just drop the idle level a little.
I did this Saturday morning before I went to the gun show and it worked. I was gone all day and repeated Sat. night and it worked again!
Sunday I went riding with my son and the same routine worked again.
That's three consecutive attempts from a dead cold engine and all three times my bike lit off within 2-3 kicks.
I admit that I don't understand why it works, though.
Doesn't a higher idle adjustment just crack the slide open a bit to let more air in? My bike isn't running rich on the slow circuit, though. I went from a 65pj to the 68pj because of some popping down low and an erratic return to idle, which I think means too lean on the slow circuit.
I don't friggen care. It works fine now and I aint gonna mess with it!
Thanks guys for all the help and letting me vent. :busted: :crazy:
  • onebigmike
Posted January 28, 2008 - 06:43 AM
#47
Glad to hear you got it figured out. Where did you go riding?
  • Rman of 237
Posted January 28, 2008 - 07:59 AM
#48
:applause: :busted: 90% of the time it's something simple. Glad you got it starting right.:cool:
  • jetfuel
Posted January 28, 2008 - 08:02 AM
#49
Glad the world is right for you once more.. nice looking piggy..:cool:
  • martinfan30
Posted January 28, 2008 - 09:57 AM
#50
What a releif!!
  • Denn10
Posted January 28, 2008 - 03:15 PM
#51
What a releif!!
i know i was getting ready to throw something at the Sploog!!! LOL im sure this will be one to remember for a while. I dont remember alot about idle making it so hard to start. Good job Sploog
  • martinfan30
Posted January 28, 2008 - 03:41 PM
#52
If the idle is too low, the throttle plate isnt letting any air in. I've done it to mine!:cool:
  • Krannie McKranface
Posted January 28, 2008 - 04:12 PM
#53
Maybe it's your OLD starting procedure on your NEW motor that's giving you trouble.
Now that you have opened her up, you need to give her more gas.
- 5 kicks with no gas and decompression on
- Gas on, three squirts
- Raise the idle
- TDC, and kick.
- NO choke
  • sploogemonkey
Posted January 28, 2008 - 05:03 PM
#54
I was gettin' nervous, afraid I might not get it figgered out before April, afterall, I gotta go find that Husky Memorial in the desert this spring.
You gonna make it for the weekend camp-out, Denn'? Shootin' for April or May.
  • martinfan30
Posted January 28, 2008 - 05:06 PM
#55
SPLOOGE, take a look at the sticky I have posted...
Fell Off Trailer by usafxr
  • Hot  43 replies
  • Hot  60 replies
  • Hot  186 replies
  • 4 replies
  • 22 replies
