Soon to be Xr650R Owner..Decompressor?
8 replies to this topic
  • Sixotoo
Posted January 21, 2008 - 08:26 AM
Sorry if this is a dumb question but what exactly is the decompressor lever used for? Is it used under normal riding conditions / situations or only for starting? I remember when I was a kid (I'm 47 now) a neighbor had a Honda 125 that had a compression release that he used constantly while riding. I assume that a compression release lever and a decompressor are the same thing. Is the auto-decompressor designed for easier starting or only to control kickback while starting?
BTW I am picking up a 2000 XR650R on Wednesday!! I'm so excited. Current owners says everything is still stock except for gas tank and street kit so I will have some work to do before spring. Can't wait.
  • martinfan30
Posted January 21, 2008 - 11:46 AM
The auto -decomp is used for easier starting. You dont need to use the decomp lever unless starting.
  • husky123
Posted January 21, 2008 - 12:47 PM
makes it much easier to get that massive piston just past TDC.
  • XR4DEZ
Posted January 21, 2008 - 05:10 PM
Good to use to clear the bike out after a crash.
  • Old_Man_Time
Posted January 21, 2008 - 11:04 PM
Also they are used for compression starting down a hill. Just pull it in while rolling and slowly release. The rear wheel never slides and the bike just starts.
  • Maroast
Posted January 21, 2008 - 11:38 PM
Yup.
With the ignition switch off, crack the throttle wide-open and hold it. with your left hand pull and hold the decomp lever and kick the bike swiftly 10-20 times (depending on how bad you flooded it).
Then close the throttle, turn the power on, find top-dead....and one nice swift kick should light er up.
If the bike your getting has an edelbrock carb on it, then this little dance is rarely needed or used.
  • Thunderbug
Posted January 21, 2008 - 11:51 PM
And the little lever ting-a-lings at RPM and gives you something to listen to.
  • XR4DEZ
Posted January 22, 2008 - 10:18 AM
Yep, so I wear earplugs and chew gum.:cool:
  • Suikerland
Posted January 23, 2008 - 01:42 AM
I just learned something new.
BTW I used ride an old XT500, always used the decompression when starting. It had a fierce kickback.
But on my 650R I never use the decomp. Just push the kickstart slowly an inch past TDC, then back a bit, then big kick.
  • 17 replies
  • 22 replies
Honda XR650L 2017
  • 0 reviews
Honda XR650L 2016
  • 0 reviews
  • Hot  29 replies
