Strange Vibration....
5 replies to this topic
  • eyeofth3b3hold3r
Posted January 20, 2008 - 10:16 PM
Hey everyone, I have a 1995 honda xr650l thats desmogged and the stock pipe is gutted, everything else is stock. My problem is i have some type of vibration when you put the bike in a high gear to run at that current speed to maintain a low engine RPM, when U don't give it much throttle theres no vibration but when you roll on a lot of throttle a rumble kinda happens near my feet and i feel in it the seat. when the bike is just ridden hard up through the gears and in each gear at a high rpm there is no vibration. and the when the bike does vibrate the its not really struggling to pull the bike, it still accellerates and goes fine with the vibration. i'm wondering what is causing this? my bike has 14,500 miles and the tires, chain, and sprockets are all good. i've had crappier bikes do much worse things for thousands of miles, should I worry about this? Thanks!!! and i love my pig. also, i'm painting whats not white on my bike white, and painting the rims black, this should look cool when i'm done!! its a clean bike to start with! thanks for your help everyone!
  • Krannie McKranface
Posted January 20, 2008 - 11:12 PM
It sounds like normal 'thumping' of the motor. It is rythmic, and does it diminish more as the rpms go up?
  • philipstjohn
Posted January 21, 2008 - 04:43 AM
Put new knobbies lately, tire balance issue?
  • eyeofth3b3hold3r
Posted January 21, 2008 - 06:11 AM
yeah it does go up as the rpms go away so I guess thats what a huge thumper does? thanks!
  • BeeDub
Posted January 21, 2008 - 08:33 AM
Maybe I'm reading it wrong, but it sounds to me like you might just be "lugging" it. My bike's brand new, and it'll do that if I try to lug it too much. I'm new to the L too, and this bike has a very different feel to the gears than any bike I've had. You can almost do freeway speeds in 3rd gear...
  • martinfan30
Posted January 21, 2008 - 09:00 AM
Wlecome to the big bore thumper world!
You may also be lugging it a bit. Just for fun, check all your engine mount bolts, suspension bolts, etc...
