01 650l hard to start-spark problem!
8 replies to this topic
  • award900
Posted January 20, 2008 - 02:18 PM
With spark plug pulled, I only get a spark when I hit the starter and when I let go of the starter. It does'nt keep sparking as I hold it. Trying to start it when cold takes some patience ( and a few backfires!) but once i get it to run, it runs fine, and starts up when warm. Typical mods, dave,pipe,de smog, k & n. etc. Thanks for your time!
  • martinfan30
Posted January 20, 2008 - 05:25 PM
Sounds like one of the safety switch's may be activating the KILL.
  • XR650L_Dave
Posted January 21, 2008 - 09:15 AM
Someone on here posted a similar problem, if you're getting spark when you wack the starter on, nothing while cranking, then another spark when you let go, seems like a weak spark vs. no spark.
To rule out the safeties, you can ground both wires that go to the clutch-lever switch. This will bypass the kickstand switch, the neutral switch and (of course) the clutch switch.
This sounds more like a bad ground, bad coil, bad plug, bad plug-cap resistor, bad CDI or bad piockup problem, though.
Investigate from cheapest to most expensive-
Dave
  • Red4x4neck
Posted January 21, 2008 - 12:01 PM
I am having the same issues right now.
Think that I may have a dying CDI or Pulse generator.
Rob
  • award900
Posted January 21, 2008 - 09:26 PM
Thanks Brothers! It is hard to find motivation to wrench when it just warmed up to 6 degrees! We are takin the mini's out to the lake this weekend!
  • martinfan30
Posted January 22, 2008 - 11:58 AM
The mini's?
  • award900
Posted January 22, 2008 - 05:18 PM
The mini's?
Kawasaki KLX 143s, of course! I would guess you don't have many options for riding on ice in Nevada, huh.
  • martinfan30
Posted January 23, 2008 - 11:37 AM
The lakes do freeze here, only do some ice fishing. Ice riding, no way!
  • Denn10
Posted January 23, 2008 - 12:32 PM
whats wierd is it runs fine but starting only sparks intermittend, if its running strong all the time you may wanna check electrical out. I know thats alot but it has to be in there somewhere. Got another CDI box to try out?
  • 17 replies
  • Hot  29 replies
  • 3 replies
Honda XR650L 2017
  • 0 reviews
  • 9 replies
